relocating sterling breather tube - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2008, 11:19 AM   #1 (permalink)
Member # 16680
anyone relocate, or think of a reason it cant be reloacted to the top of the pumpkin. Was looking to put it on top of the machined flat surface where the brake line clip bolts down. The only thing I can think of is gear oil slosh from the ring.
plug ugly is offline   Reply With Quote Quick reply to this message
Old 02-02-2008, 06:42 PM   #2 (permalink)
Member # 50245
Send a message via MSN to chrono4 Send a message via Yahoo to chrono4
I dont see why that would be a problem. If the tube has any sort of length to it, it will never reach the end of it. Or if it is ever a problem, a small breather element on the end would cut that down.
I'm a web wheeler
Working on a 79 f150...... lots to come
chrono4 is offline   Reply With Quote Quick reply to this message
Old 02-02-2008, 06:44 PM   #3 (permalink)
Member # 92867
just curious why do you want to do that? did you break it off b4 or somthing?, but i dont see a problem with it...
96' F-150....460/c6/205/200 on rockwells
78' Bronco- 408m, C6, NP205, chromos, 40" boggers....
BOGGER1966 is offline   Reply With Quote Quick reply to this message
Old 02-02-2008, 06:50 PM   #4 (permalink)
Member # 50245
That extra 6 inches of line adds weight
I'm a web wheeler
Old 02-02-2008, 08:04 PM   #5 (permalink)
Member # 16680
IM inboarding some chevy rears on the bronco, and wanted to clean things up a bit while I was at it. Planned to put a center limit strap, and figured I would plumb the brake line drop and breather right next to it.
Old 02-03-2008, 04:50 PM   #6 (permalink)
Tech Tim's Avatar
Member # 19067
Just make sure to tack a small piece of sheet metal over the top of it as a baffle to keep the gear oil from getting slung into it.
3/8" ID minimum.
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Tech Tim is offline   Reply With Quote Quick reply to this message
Old 02-03-2008, 07:38 PM   #7 (permalink)
III
Chris's Avatar
Member # 2032
I've done it, it works, I did it because I broke off the stock one.Didn't use a baffle, never leaked any oil.
Chris is offline   Reply With Quote Quick reply to this message
Old 02-03-2008, 09:48 PM   #8 (permalink)
Member # 16680
did you put it in that same flat area I am talking about?
Old 02-04-2008, 07:31 AM   #9 (permalink)
Tech Tim's Avatar
Member # 19067
It's not about leaking oil, it's about getting oil in the vent line and not allowing the housing to breathe properly.
Tim Lund
