P/S pump Pully - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-08-2002, 07:33 PM   #1 (permalink)
Member # 8519
Send a message via ICQ to Thumper046 Send a message via AIM to Thumper046 Send a message via Yahoo to Thumper046
P/S pump Pully
How the hell do you get the Pully of the Power Steering pump of a FORD . I have done seaches on here the NET can not find any info. Neither my "Chiltons" nor my "Haynes" say anything about it. All I want to do is put the braket from one pump to another
Is it some Ancient American Ford secret or something???
PLEASE HELP!!!!
Keep the rubber side down!!!
Absolute power corrupts absolutely,
Which is a problem if your absolutely powerless.
Thumper046 is offline   Reply With Quote
Old 07-08-2002, 08:14 PM   #2 (permalink)
Member # 324
You need a puller. Autozone will lend you the puller.
Family, Friends, riders and racers, its who we are.
smurfsdad is offline   Reply With Quote
Old 07-08-2002, 08:26 PM   #3 (permalink)
Member # 8519
just a puller? You dont have to undo a center bolt ????? if this is it then, will I have to have the thing pressed back on? Or am I missing a step here. Just bear with me I have never dealt with a ford and am learing as I go
Old 07-08-2002, 08:54 PM   #4 (permalink)
Member # 6733
Assuming your pump looks like mine (FS Ford truck), the pump shaft will end flush with the pulley. There will be a threaded hole in the center of the shaft.
The puller is a "clamshell" type. Two jaws lock around the flange on the pulley, a bolt goes through the middle and threads into the pump shaft. Hold the bolt with one wrench, and back off the puller with another.
Installation is the reverse. Thread the bolt into the shaft, crank on a nut to press the pulley back on.
Like they said, you can borrow it from Autozone for a deposit. P/N 27031
saf-t scissors is offline   Reply With Quote
Old 07-08-2002, 08:54 PM   #5 (permalink)
D60
D60's Avatar
Member # 6398
IIRC you should have to remove the center bolt. The puller will also press it back on for you.
"Take 300 people and on average 290 of them just generally suck at life"
D60 is offline   Reply With Quote
Old 07-08-2002, 09:24 PM   #6 (permalink)
Member # 8519
Damm......You ever have one of those days when you feel like you just are missing the BIG PICTURE!!!!!!
Thanks all I will get hoping on this.
Thanks again, for you have shown the little green grass hopper the light
