questions about the computer in a 1987 5.0 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-08-2008, 11:08 PM   #1 (permalink)
mattgersh8's Avatar
Member # 81957
Send a message via AIM to mattgersh8
i have an 1987 town car i am pulling the 5.0 out of for my truck, it had an auto tranny in it but its bad so i was wondering if i was to swap the tranny would the computer mess up because the plugs aren't plugged in idk if the computer is new enough to look for that sort of thing, also if i pull the smog stuff of such as the pump are there sensors that will not be plugged in that will make the motor not run right? my truck is a green sticker truck so i am not worried about smog i was just curious if these things will make it not run right.
f toy with some stuff and things under it
mattgersh8 is online now   Reply With Quote
Old 03-09-2008, 12:01 AM   #2 (permalink)
Member # 50245
Send a message via MSN to chrono4 Send a message via Yahoo to chrono4
on an 87 it wont matter
I'm a web wheeler
Working on a 79 f150...... lots to come
chrono4 is offline   Reply With Quote
Old 03-09-2008, 04:48 AM   #3 (permalink)
RTM
Member # 44404
i think in 87 the trans is control by the detent cable and not the computer.
RTM is offline   Reply With Quote
Old 03-18-2008, 10:07 AM   #4 (permalink)
Member # 110298
'87 controled the engine only. Trans was controled by an adjustable throttle valve cable.
'05 Ram 2500 4x4
Hemi, LT285/70r17 MT/Rs
royo is offline   Reply With Quote
Old 03-18-2008, 10:16 AM   #5 (permalink)
vintagespeed's Avatar
Member # 25551
Send a message via AIM to vintagespeed Send a message via Yahoo to vintagespeed
you can remove the TAB/TAD & CANP controls, the EGR solenoid will need a resistor to fool the computer, they're cheap on eBay.
any trans will work fine, you'll need to bypass the NSS if you use the EEC starter solenoid circuit, also you may want to swap in a computer from a manual 5.0 to avoid stalling if you dont use an auto w/VSS behind the 5.0.
read the TOTW 5.0 thread, all this is covered there.
-jb Stop Islam Now, preserve America for Americans
vintagespeed is offline   Reply With Quote
Old 03-18-2008, 11:04 AM   #6 (permalink)
beartj's Avatar
Member # 30026
Send a message via AIM to beartj
I have a 90 speed density crown victoria 5.0L motor in my buggy. It originally had an auto.
I'm running a 4spd T19 behind it and it runs great. The VSS is ziptied up out of the way and is not connected to anything.
I pulled off the smog pump, EGR, TAB, TAD, CANP but left the EGR valve position sensor on.
It runs great. Just finished the swap a couple weeks ago took it to the badlands for the shakedown run and came back from a week in harlan, ky a couple days ago. No problems.
PORCer Fuggy
The Coyote
beartj is offline   Reply With Quote
Old 05-19-2009, 04:45 PM   #7 (permalink)
mattgersh8's Avatar
Member # 81957
problem solved
i ended up finding a propane setup for my chevy 350 i currently have in my toyota for a good price so the 5.0 is sittin in our shop waiting for another project to go in, probably a hot rod for my dad if he will ever get away from damn carbs. he is too old school like that
