can i add a crossmember? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-17-2008, 01:52 AM   #1 (permalink)
Member # 99291
my 2000 f250 super duty with a 5spd manual transmission that actually broke where it mates up to the transfer case. i replaced the rear half housing of the transmission and everything is fine now.
i figure the reason this happend is because the transfer case is supported only by the transmission and nothing else. can i build a crossmember to support the transfer case somehow or would adding another crossmember cause other problems?
drive a hybrid, i need your gas
2000 F250 Super Duty 4x4 5spd V8
steve604 is offline   Reply With Quote
Old 03-17-2008, 07:15 PM   #2 (permalink)
locked's Avatar
Member # 34418
As long as you match the bushings used in the engine and tranny mounts (Poly or likely Rubber) you should have no problems. You don't want anything that allows the engine or tranny to move in a way the transfer case can't after adding the mount.
locked is offline   Reply With Quote
Old 03-17-2008, 07:23 PM   #3 (permalink)
Member # 71454
Exactly.
I would make something like this that bolts to the case. just my $.02.
[URL="http://www.pirate4x4.com/forum/showthread.php?t=652521&highlight="]03 F-350 6.0L, 5R-110, NP271, F&R steer Rock's, lincoln lockers , and 46 XL's[/URL]
81 toy piece of shit, blown up 22r, L45, duals, 8" toy's, lincoln lockers, 35 mtr's
[URL="http://www.pirate4x4.com/forum/showthread.php?t=934882"]Shit for sale[/URL]
[SIZE="5"][B]F_CK YO_[/B][/SIZE]
would you like to buy a vowel?
[SIZE="3"][U]Kyle Anthony Lucas[/U] [B][U]RIP[/U][/B][/SIZE]
03f350 is offline   Reply With Quote
