D70 ff 8 lug to 5 lug - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2008, 07:25 AM   #1 (permalink)
caryt's Avatar
Member # 27775
Possible to do?..what about fitting a 4.128 hole wheel over the hub..turn down or is their a replacement..kit?
Thanks, Cary
caryt is offline   Reply With Quote
Old 03-23-2008, 11:12 AM   #2 (permalink)
mj
Member # 1919
anything can be done but the question is why?
8 lug works and is the cheapest choice
mj is offline   Reply With Quote
Old 03-25-2008, 08:38 AM   #3 (permalink)
caryt's Avatar
Member # 27775
Maybe because I want to..its obvious that I have 8 lugs since I am asking about changing it!
Cary
Old 03-25-2008, 08:47 AM   #4 (permalink)
Aggro's Avatar
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
The only way I know of is to use a chevy 70hd with it's 14bolt spindles and hubs. Other axle bolt flanges are a larger od and won't fit the 5 on 5.5 lug pattern.
There was a vendor who offered aftermarket hubs in 5 lug variety though.
Aggro is offline   Reply With Quote
Old 03-25-2008, 10:48 AM   #5 (permalink)
caryt's Avatar
Member # 27775
Thanks, I'll check out to see if its possible to swap the spindles and hubs to Chevy...if I understood you correctly.
Cary
Old 03-25-2008, 12:59 PM   #6 (permalink)
Member # 4243
The shafts need to match the hubs. The whole deal is GM used a smaller bolt pattern on the hubs/axles which leaves some meat you can remove.
90-93 CTD jalopies
u2slow is offline   Reply With Quote
Old 03-25-2008, 09:00 PM   #7 (permalink)
mj
Member # 1919
Grady's was the vendor
bling billet anodized aluminum hubs
spending huge $$ to save little
