Member # 75732
I have a 97 f150 witg the 4.2 2wd. I am wanting to hook up an aftermarket tach. but need some help. The directions say to hook one wire to the white wire with a pink stripe from the power control module. It should be on the pass. side of the truck. I looked under the hood but can't find the wire. Where is the PCM? There is one huge cluster of wires on the fire wall on that side and I looked for the wire they told me to but I couldn't find it. Am I looking in the wronge spot?
MASTER TECH
Member # 54844
the huge wire you speak off is the ECM plug - the wires are outside the cab - the ecm is under the pass kick panel - it is around 1.5" x6x7
but i dont know which wire it is -
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy /forum/ford/544813-update-pics.html |
#4 (permalink) | |
Damn you chuckie...
the word "wrong" does not contain the letter E.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:Build thread: ![]() ![]() Here The un-named buggy - 2.3L, lotsa tube, and FJ80s.
