F350 Desireable axles for 4X4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-20-2008, 11:45 AM   #1 (permalink)
asonico's Avatar
Member # 98299
BillaVista's list of desireables goes:
1978-79 F-350 and some F-250 (Snofighter and High GVW packages)
1986-88 F-350 with dual rear wheels (DRW)
1988-91.5 F-350 with single rear wheels (SRW)
My question is: Why are 1986-87 F350 SRWs not desireable as IMPLIED? What's the difference between DRW and SRW for these years?
TIA,
Art
asonico is offline   Reply With Quote
Old 04-20-2008, 12:09 PM   #2 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
Maybe the 86-87 axle had ball joints, tapered axles, smaller ring gear, etc. ?
As for the differences, I'd say one axle was used in 4x4s with single rear wheel applications whereas the other was utilized in 4x4s duallies. Oh yeah, don't forget differences in WMS too.
Aces'n'8s is offline   Reply With Quote
Old 04-20-2008, 12:30 PM   #3 (permalink)
Banned
Member # 36711
Actually, IIRC... Those axles in srw form should have been TTB...?? Could be wrong.
Nor Cal Wheelin is offline   Reply With Quote
Old 04-20-2008, 02:02 PM   #4 (permalink)
Member # 36399
Yup.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 04-20-2008, 02:15 PM   #5 (permalink)
asonico's Avatar
Member # 98299
So they were Dana 50s? But we're talking F350s.
Old 04-20-2008, 03:13 PM   #6 (permalink)
Member # 110178
Doesn't matter that were talking f350's. Those ones had dana 50 TTB front axles.
EDIT Never mind I went back and checked and I was mistaken
Zukiford87 is offline   Reply With Quote
Old 04-20-2008, 03:51 PM   #7 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
So those year 86-87 4x4 F350s had TTB front ends? Learn summthin' new every day.
Old 04-20-2008, 04:09 PM   #8 (permalink)
travisford83's Avatar
Member # 99302
Found a TTB F-350 at the pick n pull about 6 months ago and I was heart broken to find the TTB front end under it.
My Truggy build thread: http://pirate4x4.com/forum/showthread.php?t=643409
85' Toy based 4 Seat Buggy 22re, W-56, dual cases with 4.7's in rear, 5.29's, Detroit/Welded, poofields, marlin hy-steer, hydro assist, linked with 18" Air Shox, RUF, front range x-member, 38" TSL's, and some tube
travisford83 is offline   Reply With Quote
Old 04-20-2008, 04:13 PM   #9 (permalink)
Member # 87119
Send a message via AIM to Captainp4u1
80-85.5 was ttb on f350 I believe.
I don't have an answer on the 86-87 though.
Captainp4u1 is offline   Reply With Quote
Old 04-20-2008, 06:53 PM   #10 (permalink)
Member # 103170
1986 (august 1985 and on) was the reintroduction of the king pin HP dana 60. From the last dozen f350's that ive parted out, the only difference you will notice is between the ball joint and king pin models as well as the differences in pinion offset compared to the 78-79 models. So to clarify, 1986 and 1987 have DANA 60. If you need proof, I think I still have images from the 86 quad I had, and 3 1987 quads. Nothing puts a smile on an ol' Dodge owners face quite like a parted out Ford 350...
MikeThomas is offline   Reply With Quote
Old 04-21-2008, 07:21 PM   #11 (permalink)
asonico's Avatar
Member # 98299
Mike, please do me a favor. Would you get a measurement of the distance of the centerline of the pinion to the inner surface of the brake rotor. I'm trying to determine which (a 78-79 or 86-91 axle) would line up better with the transfer case that's already installed in my custom monster van.
Thanks in advance.
Art
Old 04-21-2008, 08:14 PM   #12 (permalink)
Banned
Member # 36711
You are correct. The f350 ttb cut off, was late or mid 85...
I stand corrected.
Old 04-21-2008, 09:19 PM   #13 (permalink)
Member # 77718
All 85 D60's were dually. 86-92 you could get a sinlgle wheel. When I got mine it had the dually bolt on hubs. They just unbolt. I havn't personally seen a 85-92 F350 TTB, but no doubt could be out there.
'89 B2 with slight modifications
[QUOTE=AZFord4x4;8084876] I really shouldn't download so much porn while I'm trying to ban people.[/QUOTE]
IROK Cherokee is offline   Reply With Quote
Old 04-23-2008, 12:32 PM   #14 (permalink)
Member # 112958
1980-85 F350 was Dana 50 TTB. 1986+ was back to D60s. of course there are always those freak cases where left over axles were put under trucks built at the begining of the new year and such
Howdy Im Scott. 1990 F150 4X4 302, 5 spd | 2000 Ranger
STGs Minions:I DRINK FROM A CUP CALLED FEAR
godblessmud is offline   Reply With Quote
