5.0 and ZF? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-17-2002, 09:20 AM   #1 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
5.0 and ZF?
I want a 5 speed behind a 5.0, was thinking the t5 is too weak, and was wondering if the ZF was ever offered behind this motor?
Originally Posted by fatdan460 View Post
it leads to real abuse, like guys who will smack a broad in the head
For Sale!! F150 5x135mm wheels!!
Wanted, Ak parts, kits or whole rifles!
Gozuki is offline   Reply With Quote
Old 07-17-2002, 09:34 AM   #2 (permalink)
Member # 8302
IT was offered behind the 351W in the F250's. But the 351w and 302 both have the same bolt pattern so is should be a direct swap... I think they came in the 96 and up F250's.
Rock Puppy is offline   Reply With Quote
Old 07-17-2002, 10:17 AM   #3 (permalink)
Member # 3132
no they also came in 88 f-250's .I have one. bad ass trans. it should bolt up take measurements before you start. and be carefull the bb cases look very simalar and fairly easy to mix up.
NOODLES is offline   Reply With Quote
Old 07-17-2002, 10:45 AM   #4 (permalink)
Member # 29
My 91 Ford Diesel has the ZF in it. I was thinking about swapping in the ZF with the BW t-case when I do a 5.0 swap.
Dimitri
1974 FJ40 in the works
2006 F250 crew cab longbed powerstroke for towing duties
Flatty is offline   Reply With Quote
Old 07-17-2002, 06:40 PM   #5 (permalink)
Member # 6733
Flatty, how are you going to adapt the tall bellhousing to a small block? Got a secret I don't know about?
BTW -- Most times, the diesels will have a 4.14ish first gear instead of the 5.71 1st the gas motors got.
And strangely, the 300 sometimes can be found with a ZF trans. But you're right -- they're usually behind 88-97 351 motors.
saf-t scissors is offline   Reply With Quote
Old 07-17-2002, 08:42 PM   #6 (permalink)
Member # 4073
There's a small block ZF here at the local u-pull-it, 2wd though.
Dustin S.
I had a brain-eating disease that died of starvation.
Dustball is offline   Reply With Quote
Old 07-17-2002, 11:29 PM   #7 (permalink)
Member # 4176
Are you sure thats a ZF and not the Mazda built lump of poo? I had an 89 F150 2WD and it was the Mazda built.
StoopidMonkey is offline   Reply With Quote
Old 07-18-2002, 01:13 AM   #8 (permalink)
Member # 4073
F-250, 5-speed tranny, had trans code Z on the door jamb sticker
Dustin S.
Old 07-18-2002, 06:23 AM   #9 (permalink)
Member # 6733
Mazda M5OD-R2 (this one with 2wd tailshaft)
ZF S5-42
Note the diagonal ribs, PTO ports, and the sexy "ZF" on the side.
Old 07-18-2002, 09:02 AM   #10 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
Will the ZF bolt to a 205?
Old 07-18-2002, 10:06 AM   #11 (permalink)
Member # 2139
Send a message via Yahoo to FordPowr
Yup...same spline and bolt pattern. But you may need to put a notch in the adapter for the 205's shift linkage
FordPowr is offline   Reply With Quote
Old 07-18-2002, 05:04 PM   #12 (permalink)
Member # 6733
.... and I would definitely provide a stout mount for the 205. Those ZFs are far too $$ to be needlessly breaking cases and tailshafts.
