smallblock C6-205 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-18-2002, 05:10 PM   #1 (permalink)
Member # 8843
Send a message via AIM to offroadr35
smallblock C6-205
has anyone found this elusive combo? I'm not happy with the C4-D20 and want something beefier after my 5.0HO. I'm pretty sure this combo exists, i just can't seem to find it. Also does anyone have pics of a 205 in an EB? They look to be a good bit bigger than the D20.
-Steve
offroadr35 is offline   Reply With Quote
Old 07-18-2002, 05:19 PM   #2 (permalink)
Member # 2006
I have it in my 70 van and my budy just put in his 66 eb . call me and I can help email me for my # ford@cnmnetwork.com
WHY DO BRONCOS GO SO FAST?? WE CAN !!!
ford is offline   Reply With Quote
Old 07-18-2002, 10:04 PM   #3 (permalink)
Member # 10622
I've got that combo in my ride. Take regular smallblock C-6, and put the Output shaft in it from the 'bigger block C-6 NP205'. The shaft is shorter than the NP208 output. From Bell to rear flange I got 41.5". The NP205 is close to 60lbs. heavier.
I've blown everything in my 9" (gear set, carrier, axle shafts'MOSER', 2 driveshfts, and about 50 U-joints), the C-6 and 205 haven't missed a beat.
'85 Bronco III
Rogue Bronco is offline   Reply With Quote
Old 07-19-2002, 02:29 PM   #4 (permalink)
Hillbilly's Avatar
Member # 857
Like Rogue said you'll proably have to build your own, I don't think the C6 with the small block pattern ever came in a 4wd
Hillbilly is offline   Reply With Quote
Old 07-19-2002, 02:59 PM   #5 (permalink)
Member # 10622
The small block C-6 did come 4X4, it came with an NP208.
Aluminum, Chain driven, Better low, and much wider.
Just swap output shafts, use the NP205 + 205 adapter (shorter).
It all bolts up, no fabbing.
'85 Bronco III
