Reinforcing D44 Radius arms - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-21-2008, 08:30 AM   #1 (permalink)
Member # 111759
I have one of the ever so hated 79 D44's with the cast wedges. I am going to run the stock radius arms on it. Anyone reinforce the radius arms? I'm not trying to spend 600 on the Duff kit. I figure I will truss the housing (I know about using nickel rod to weld to cast) and then beef up the radius arms, maybe put a heim on the end. Thoughts...pictures...
(woo hoo first post)
VB CJ 5.7 is offline   Reply With Quote
Old 05-21-2008, 09:34 AM   #2 (permalink)
Dirt Engineer
Clodhopper's Avatar
Member # 23542
Yep, filled in the sides with 3/8" plate. Welding it without turning it into a banana was fun, but ended up relatively straight, only minor tweaking with a press. Haven't bent them yet and that was 3 years ago. Not sure if I have pics, but I will look around.
I doubt I would do it again. Faced with the same problem, I would probably chop the axle end off and fab up stronger arms.
Clodhopper is offline   Reply With Quote
Old 05-21-2008, 06:31 PM   #3 (permalink)
Member # 111759
I have seen where guys have cut the arm off and just used the C's and fabbed up their own arms. Didn't think about the steel warping... hmmm...
79 CJ5... revived and promptly sold...
91 YJ with some shit bolted on...
Old 05-21-2008, 06:43 PM   #4 (permalink)
William Grimsley's Avatar
Member # 55497
I boxed mine and reinforced the C's as the tech article in bronco driver magazine describes. Been running them a couple of years with no problems
72'EB,302.435,44/9''5.38 Detroit's 38 SX 's
74' EB SEFI 351W. 96' FJ 80 , 2" body lift.
William Grimsley is offline   Reply With Quote
Old 05-21-2008, 07:09 PM   #5 (permalink)
mj
Member # 1919
there was a thread on here with tons of ways to extend the arms
my fav was the one where he whacked the arm off leving a 4-6" stub and made the rest with box tubing that looked about 2.5" or 2".
sounds cheap but the execution shown on that thread was real nice
mj is offline   Reply With Quote
Old 05-22-2008, 08:33 AM   #6 (permalink)
Moderhater
Halogrinder's Avatar
Member # 16980
My thread has some pics of mine.
Im your BMW huckleberry
https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car!
gun facts that will blow your mind:
http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf
Halogrinder is offline   Reply With Quote
Old 05-22-2008, 08:54 AM   #7 (permalink)
GubNi's Avatar
Member # 25927
I don't know if I'd trust two heims to hold on the front axle. The stock setup with bushings flexes really well.
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here
Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here
Dana 60 front 3/4 ton kits $350--> click here
GubNi is offline   Reply With Quote
Old 05-24-2008, 08:21 PM   #8 (permalink)
Member # 110615
I cut and extended mine. then plated the out side. I used 1 1/2" .330' wall dom tube. I slotted the tube and the stock arms. They work very well.
66 Resto Mod, 66 Rockrawler
66gasgrill is offline   Reply With Quote
Old 05-25-2008, 06:35 AM   #9 (permalink)
Moderhater
Member # 16980
nice! i would run a peice of 1"x1/2" strap on edge down the length of the tube and arm to give it rigidity. it would make that whole arm MUCH stronger.
i would have a feeling i would bend that. its freakin long!!
Old 05-25-2008, 12:47 PM   #10 (permalink)
Member # 94725
ya that looks like it would bend fairly easy
i dont understand why you guys dont make the extended arm with 2 pieces of thick wall / DOM tubing converging at the frame end. similar to a ladder bar. one big long triangle which would be a helluva lot stronger than one single tube.
79 Ford
TroyM is offline   Reply With Quote
Old 05-25-2008, 03:40 PM   #11 (permalink)
Simply awesome!
Member # 5679
On a YJ
1bgdog is offline   Reply With Quote
Old 05-25-2008, 04:33 PM   #12 (permalink)
Member # 77718
Originally Posted by 1bgdog View Post
On a YJ
WTF
'89 B2 with slight modifications
[QUOTE=AZFord4x4;8084876] I really shouldn't download so much porn while I'm trying to ban people.[/QUOTE]
IROK Cherokee is offline   Reply With Quote
Old 05-25-2008, 04:39 PM   #13 (permalink)
Member # 14600
On a YJ
Holy Crap! Did that extension bend or was it fabbed that way---------Hans
Just a redneck trapped in a brown man's body
Oatmeal is offline   Reply With Quote
Old 05-25-2008, 05:08 PM   #14 (permalink)
Simply awesome!
Member # 5679
Talking
Originally Posted by IROK Cherokee View Post
WTF
It's a Jeep thing....you guys wouldn't understand. We don't need to stretch it all the way to the rear of the rig to make it flex.
Old 05-25-2008, 05:20 PM   #15 (permalink)
Member # 25325
Send a message via AIM to redranger4.0
Yea apparently you dont need to weld either, you just had to blow your nose on it and it holds up.....
redranger4.0 is online now   Reply With Quote
Old 05-25-2008, 05:26 PM   #16 (permalink)
Simply awesome!
Member # 5679
Question
What have you added to this post?
Have you seen the welds personally?
Have you seen the rig on the trails?
My set up is similar 66gasgrill but a different application.
Haters the whole bunch of yous!
Old 05-25-2008, 06:38 PM   #17 (permalink)
Moderhater
Member # 16980
i feel some butthurtedness here
Old 05-25-2008, 08:55 PM   #18 (permalink)
Member # 110615
I had something like that happen to my first set of arms. Not near as bad but enough to cause concern. I agree a ladder bar type arm would be much stronger and mine are long and will bend some, but they won't break. Anyway the guy said he wanted something cheap-cheaper, I was offering up an option. I am actually in the process of redoing my suspension so these will go away.
Old 05-25-2008, 08:58 PM   #19 (permalink)
Moderhater
Member # 16980
dude they will be plenty strong if you put a peice of 1''x1/2'' strap on edge and weld it the length of the top of the arm.
Old 05-25-2008, 09:03 PM   #20 (permalink)
Member # 110615
:Edit Double posted this part Edit:
Back to the original question, the stock arms are plenty strong but if you really want to truss them just cut your plate to fit and have at it If you want to add heims you can do it an infinate number of ways. Adding some tube to the end is probably the easiest. HTH.
Old 05-25-2008, 10:20 PM   #21 (permalink)
Member # 25325
A sliver of comedy...
Old 05-26-2008, 10:12 AM   #22 (permalink)
Member # 110615
You mean like this? This is one of Broncomania's rear links.
That is a very good Idea I''ll have to do that.
Old 05-26-2008, 10:18 AM   #23 (permalink)
Moderhater
Member # 16980
si. that helps out tremendously.
Old 05-26-2008, 05:07 PM   #24 (permalink)
Member # 77718
No you don't need them to be that long, but you do need to build the extensions better than that......
Old 05-26-2008, 05:47 PM   #25 (permalink)
brewchief's Avatar
Member # 71185
On a YJ
Is it just me or does that "extension" look like a tractor link cut in half?
With no gusseting I'd expect that arm to fold up with a good bump to the front axle.
Brewchief
brewchief is offline   Reply With Quote
