d44 ttb bearing removal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-03-2008, 09:00 PM   #1 (permalink)
Member # 112027
ok guys sorry total noob to this here. i searched and couldnt find what i was looking for. im working on a d44 ttb setup trying to remove the bearings and rotor and cant for the life of me figure out how. i know its something super simple and im missing something totally easy. its all the way down to what looks like a circle piece with a bunch of holes in it, is there s special tool needed to remove that????
carlover is offline   Reply With Quote
Old 06-03-2008, 09:36 PM   #2 (permalink)
Member # 10063
The circle piece with holes in it sounds like the locking washer. That washer should be just sitting there if you've removed the outer bearing locknut, it should come right out with a screwdriver or other tool to reach in there with.
What year D44 is it? Some of the very late ones ('95, '96 IIRC) had a screwy design on the auto locking hubs, maybe some part of it is still in need of removal (unfortunately I'm not real familiar with these)
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 06-03-2008, 09:55 PM   #3 (permalink)
Member # 112027
have no idea what year its out of. actually just using the snouts to build custom spindles. its free floating i can tell that much but i will try to pry it out a little harder lol. thanks for your help.
Old 06-03-2008, 11:58 PM   #4 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
Send a message via AIM to svt150j49
its just sitting in there. there should be an adjustment nut, the washer, then another nut.
the grease holds back the washer most of the time. stop being a pussy.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread:
Here
The un-named buggy - 2.3L, lotsa tube, and FJ80s.
svt150j49 is offline   Reply With Quote
Old 06-04-2008, 06:06 AM   #5 (permalink)
Member # 67169
Dental picks are your friend.
1987 BroncoII that's far from stock
Joel H is offline   Reply With Quote
Old 06-04-2008, 05:03 PM   #6 (permalink)
Member # 112027
Got it out last night, thanks guys lol. Yeah im a total newbie to this shit, but its all good. Thanks for the help again...
Old 06-04-2008, 05:06 PM   #7 (permalink)
Member # 36399
Mine had the ratchiting nuts....Mucho better.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
