Member # 113828
noob ?... what keeps the axles in the 9" rear end??
Ok.. so maybe i am having a brain fart here.. but how are the axles held in place on the 9" rear end?? I know they have to be pulled out before the 3rd member can be removed right? And looking at the exploded views, its looks like there are caps with 4 bolts that hold the bearings into the outer axle tubes.. but how is the bearing kept on the inner axle shaft? just a press fit?? and is this all that keeps the axles from getting pulled out when driving? i gotta be missing something here..
I have never pulled apart this type of rear end before.. so forgive me if these questions seem totally retarded... and thanks for the help!
Daily driven 04 WJ, 4.7 HO, 242 swap, beadlocked 35's, Custom Winch Bumper |
Member # 91164
yes the 4 bolts on the outer tube hold the axles in. its much stonger that its replacement the 8.8 that uses c clips. as for the bearing it rests against a raised collar i guess you could call it.
hope this helps |
#8 (permalink) | |
Member # 94725
79 Ford |
Member # 113828
right on.. how does the bearing retainer/ raised collar attach to the axle?? is it threaded on?
thanks guys g-
#11 (permalink) | |
Member # 36399
How the fuck would it thread onto the axle dumbfuck?
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks 95 F-150 6" of lift, SAS 35" BFG's |
#12 (permalink) | |
Yes, I do know that the bearings are pressed on, and that this guy has got to be almost as uber ghey as the re-visited high boy poster
[QUOTE=beater82;10834814]200,000,000 privately owned firearms in this country and you think we're gonna' run to your frozen ass nanny state to get away from that fuckin' socialist pimp? What the fuck do you think we are? Descendants of the french?[/QUOTE] [QUOTE=Elwood Blues]Blessed Lady Of Acceleration, don't fail me now![/QUOTE] Last edited by willys101_4lo; 07-27-2008 at 06:31 PM. |
#13 (permalink) | |
Driven by hate
You can check-out any time you like, But you can never leave! |
#14 (permalink) |
Member # 113828
You can't see how its all held together by just looking at it, and i don't want to take it apart... just curious how it works..
#17 (permalink) |
Member # 113828
Wow.. obviously you have problems with comprehension.. no shit the bearing retainer holds it all in.. you must of missed my response that said thanks..
but how does the bearing retainer attach to the axle and keep the bearing from getting pulled off the axle?? all you fawking genius's with the brilliant replies can't seem to tell me that.. ![]() So the bearing gets pressed on the axle.. then a retainer goes on the axle to hold the bearing in place, correct??? So then how does this retainer hold the bearing in place?? that's all i am looking for.. is it threaded, have set screws? a press fit? is there a groove machined in the axle, and the retainer clamps around it? what?
Daily driven 04 WJ, 4.7 HO, 242 swap, beadlocked 35's, Custom Winch Bumper Last edited by LSRGreg; 07-28-2008 at 09:15 AM. |
#18 (permalink) |
Member # 17347
the question has already been answered.
you need to one of three things.... 1)stop and read 2)go look your self (it will take 5 min.) 3)go away
71.5 Bronco Wagon 1976 F100 giant pile of parts, that is finaly a roller... |
#19 (permalink) |
Member # 14600
The bearing retainer is pressed on (takes about a 12 ton press) and believe it or not it keeps it there. The ID of the retainer is actually smaller than the shaft so, it actually stretches to fit......think of it as a high strength rubber band
----------Hans
Just a redneck trapped in a brown man's body |
#20 (permalink) | |
[QUOTE=beater82;10834814]200,000,000 privately owned firearms in this country and you think we're gonna' run to your frozen ass nanny state to get away from that fuckin' socialist pimp? What the fuck do you think we are? Descendants of the french?[/QUOTE] [QUOTE=Elwood Blues]Blessed Lady Of Acceleration, don't fail me now![/QUOTE] |
#21 (permalink) | ||
Member # 113828
nobody said anything about how the retainer was held on the axle shaft until oatmeal just replied.. my head was never in my ass.. but thanks for lookin out. There is nothing wrong with my axle.. another good reason not to take it apart.. i just wanted to know how it was held together, simple as that.. yeah. pretty sure i never said anything about my axle being screwed up.. so no need to get new bearings and repair it.. but you must have missed all that since you were so worried about trying to call me an idiot.. but thanks for the help anyways.. willys101.. i hope you made yourself feel better by trying to make me look like an idiot. You can go crawl back into your hole now.For the few that did answer my questions.. i appreciate it!
#22 (permalink) | |
correct me if im wrong, but aren't ALL rear axles, that are non c-clip type, retained in this manner??
now i'm going to wait in anticipation until LSRG's next post.. "HowTF do i remove this bastard bearing retainer!!??!! "
☠ Quote:
#23 (permalink) |
Member # 113828
Damn. what's with you asshats??
i think i am going to go cry in the corner now.. ![]() can't a guy just ask a simple question?? i bet you all popped out of your Mom's womb knowing everything huh... my bad.. i forgot that some of us were this lucky. Forgive me for wanting to increase my knowledge.. The only rear axle i have pulled apart in my lifetime was a GM 14 bolt full floater.. and thats totally different.. so to all you guys that are soo freakin smart. shit.. i totally forgot this was in the Ford section.. no wonder.. your all pissed because you have to deal with your Ford taking a dump on you all the time.. i totally appologize for responding how i did.. no need to make you feel any worse about your miserable lives.
Daily driven 04 WJ, 4.7 HO, 242 swap, beadlocked 35's, Custom Winch Bumper Last edited by LSRGreg; 07-28-2008 at 02:04 PM. |
#25 (permalink) |
Whats with us asshats?
We get tired of lazy fuckers like you that come in here, ask dumb ass questions and expect us to teach you basic concepts. Press fitting is VERY simple, very old school tech, and the fact that it hasn't trickled down to Lazycuntsville isn't our fault. Neither is the fact that you are too goddamned lazy to either pull the axle apart, or look it up in a Chilton's/Haynes/factory service manual. This isn't remedial auto shop for douchebags. This is Pirate4x4, where lazy asses are flamed for asking dumbass questions. Either get fuckin used to it, or go the fuck away
