Member # 117249
C6 gear question
I have a 79 standard cab F350 with a rusty body, the good news is everything under the body is in good shape except the C6. I took it to a shop to have the trans. rebuilt and was wondering if anyone here has ever used the lower first gear from an Inline 6 engine/transmission with the V8 set up?
The truck will be used both on/ off road. p.s. I just got my new power steering pump in the mail, a rebuilt Saganaw 20-6244! They are getting hard to find with the reservoir attached, I can't believe I found one. Last edited by Recon 8427; 07-28-2008 at 06:27 PM. |
MASTER TECH
Member # 54844
only the later e40d has a diffrent panet set, and yes it has been done.
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy /forum/ford/544813-update-pics.html |
I've driven an early bronco with a stock worn out c-6 and a rebuilt c-6 with the e4od gears and what a difference. Kept cruising rpm's down but rocketed off the line like a rice rocket. It is a very worthwhile mod, I'll do it to mine if I swap in a c-6
MASTER TECH
Member # 54844
it puts the gears at 2.71 first and a 1.53 second - its something like 10% for first -
factory is 2.46 - 1.46 - 1.1 mine is getting one
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy http://www.pirate4x4.com/forum/showthread.php?t=544813 Last edited by f250rollinon37s; 07-28-2008 at 09:40 PM. |
#5 (permalink) | |
Member # 117249
Did it work out well when driven on the street? What about carring a load in the bed or towing a light trailer? My truck will be driven on the road as a DD for the next year, afterward it will be mostly an offroad toy. Last edited by Recon 8427; 07-29-2008 at 03:02 AM. |
#6 (permalink) | |
Member # 117249
Thanks for the numbers. Last edited by Recon 8427; 07-29-2008 at 03:03 AM. |
I would definitely swap an E4od gear set into your tranny. We put that gear set into my C6 years ago and love it. That extra bit of power in the low end is awesome.
2008 F-250 FX4 1997 F-150 4X4, 1998 Wrangler 1971 Bronco, 1975 F-150, 1977 F-250 |
MASTER TECH
Member # 54844
i think he ment better accel without changing the rear end gears - so its like having lower axle gears - but with a good cruz rpm
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy http://www.pirate4x4.com/forum/showthread.php?t=544813 |
#12 (permalink) |
Member # 53584
yep its been done before, there was a write up in 4wheeler or Petersons several years ago.Here is the link to a place that has the tranny rebuild kits and the lower gear sets:
http://www.broaderperformance.com/c6...sion_parts.htm if ya got it torn done that far ya might as well put a rebuild kit in it but thats just my 2 pennies
The object of war is not die for your country but make the other bastard die for his! George Patton |
#14 (permalink) |
Member # 1635
Anyone have a junkyard list? More info
Only write up I found is no longer.
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html |
#15 (permalink) |
master lurker
Member # 104639
get the stuff in the picture
![]() the factory stuff will have aluminum planet, 3 pinion, junk
--------------------------------------------------- GOT 99-04 UNIT BEARING HI-STEER?? check out the super ranger 86' RANGER-39.5'S-4.0L-M50D-9"-DETROIT-5.14'S 90' RANGER-42'S-BLOWN 302-E4OD-60/10.5-5.38'S-12 BOLT H1'S
