help me - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-05-2008, 10:23 AM   #1 (permalink)
Member # 4962
help me
you can flame all you want, but I've got a line on a 94/95 5.0 fuel injection setup, but I have to let the guy know within an hour and I don't have time to search and read everything---I have a 1971 302 in my willys---will the parts off a 94/95 bolt up to my engine----intake manifold, exhaust manifold or headers, distributor, etc----if not what yr's do I need to look into to conver to fuel injection----I'm ford illiterate, but the 302 came in the jeep and it runs good so it's not worth it to dump the engine and install a , buick, chevy or cummins in it at this point------chris
'48 cj2a --my '48 build: /forum/jeep-willys/1004065-not-build-thread-but-kind-just-tryin-help-others.html
'99 Dodge CTD 4x4
csutton7 is offline   Reply With Quote
Old 08-05-2008, 10:32 AM   #2 (permalink)
Member # 36399
So you want to go EFI? If so I would make sure the donor truck is mass air and not speed density as right about then is when it changed (my 94 has S/D, my 95 has MAF).
That would be the right setup to go EFI, but I would swap the whole motor as that one should be roller.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 08-05-2008, 10:42 AM   #3 (permalink)
Member # 4962
so the parts WILL bolt up--that's good to know---well this is just the for the intake, exhaust, distributor, wiring etc---new set up---not sure what else I'd need to buy----but thanks for the info----chris
'48 cj2a --my '48 build: http://www.pirate4x4.com/forum/showthread.php?t=1004065
'99 Dodge CTD 4x4
Old 08-05-2008, 10:42 AM   #4 (permalink)
Member # 36399
As far as I know yes.
Old 08-05-2008, 11:44 AM   #5 (permalink)
1sicbronconut's Avatar
Member # 37866
Truck or Mustang? The truck manifolds are very tall and won't fit under your Willy's hood. The 94'-95' mustang EFI set-ups are usable but are a big PITA compared to the older Mustang EFI set-ups due to a lot of extra wiring. The 94'-95' Mustang intake would work very good for your Willys because they are very low profile but I'd plan on using the later style Mustang EFI wiring. HTH my $.02
1sicbronconut is offline   Reply With Quote
Old 08-05-2008, 12:39 PM   #6 (permalink)
Member # 4962
thanks--
my neighbor was tossing some ford parts a couple of months back, so I nabbed them--they are fuel injection parts I think----I'll have take some pics and show you guys and have you guys tell me what's what and if I can use them----I remember butterfly set up, some brackets, maybe the upper intake or maybe it's the air runner to the upper manifold???---haven't looked at it for awhile, so I'm just tossing off the cuff here---chris
'99 Dodge CTD 4x4
