climate control not workin stock 99 150 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-06-2008, 02:35 PM   #1 (permalink)
molson's Avatar
Member # 44912
anyone ever have problems with their selecter switch not working (99 F150)..it seems as though all i have working is the defroster position.. or should i say that is the only place that has air blowing out..i have heat and cooling but cannot get the dash vents-floor vents-dash/floor etc..to work or "switch over"
anyone have this same thing come up before?
is their some sort of solinoid that has gone bad or possibly the switch it self?
hate to start throwing cash to the wrong parts...
any help is greatly appriciated
molson is offline   Reply With Quote
Old 09-06-2008, 02:57 PM   #2 (permalink)
Member # 56006
: laughing:
JoshTurner is offline   Reply With Quote
Old 09-06-2008, 02:58 PM   #3 (permalink)
mj
Member # 1919
not really what this forum is for
mj is offline   Reply With Quote
Old 09-06-2008, 03:06 PM   #4 (permalink)
molson's Avatar
Member # 44912
i know......just lookin for a little help.. thats all...thanks
Old 09-06-2008, 04:10 PM   #5 (permalink)
MexiCAN
Que_Honda!'s Avatar
Member # 104219
i would consider opening up the dash and taking out the stereo and such and make sure the connections are all good.
Que_Honda! is offline   Reply With Quote
Old 09-06-2008, 04:20 PM   #6 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
Send a message via AIM to svt150j49
Vac. leak. Or blend door motor, but its most likely a vacuum leak. Usually the lines by the battery crack and fail. Check there, follow them into the cab.
If you still cant get it, bring it to someone who knows what they are doing.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread:
Here
The un-named buggy - 2.3L, lotsa tube, and FJ80s.
svt150j49 is offline   Reply With Quote
Old 09-06-2008, 04:21 PM   #7 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
Most connections do not just "fail". Especially on newer vehicles. The worst thing he can do is tear into something over his head.
Build thread:
Here
Old 09-06-2008, 04:31 PM   #8 (permalink)
mj
Member # 1919
auto temp controls bypass the engine temp switch in defrost position
my 94 crownvic has similar issues with auto temp control
so I would be looking at the vac/elec coolant temp switch you can bypass it so that the fan runs at any engine temp, basically it doeant allow the fan to run til the coolant is warm except for defrost, defrost gets fan at any engine temp
Old 09-06-2008, 05:17 PM   #9 (permalink)
Driven by hate
Danger Ranger's Avatar
Member # 1234
my climate controls havn't been working right either...
do yall think it would help if I installed a roof and a windshield?
You can check-out any time you like, But you can never leave!
Danger Ranger is offline   Reply With Quote
Old 09-06-2008, 07:12 PM   #10 (permalink)
Member # 77718
Well fawk, may as well cut it up and turn it into a REAL wheeler...
'89 B2 with slight modifications
[QUOTE=AZFord4x4;8084876] I really shouldn't download so much porn while I'm trying to ban people.[/QUOTE]
IROK Cherokee is offline   Reply With Quote
Old 09-06-2008, 07:13 PM   #11 (permalink)
1sicbronconut's Avatar
Member # 37866
X2 on the vacuum leak by the battery, I seen to fix a few for that problem every month.There is also a vacuujm check valve by the battery that can go bad. The F150 system is wa diffrent than a Crown Vic when the vancuum control heaqd loses vacuum it defaults to defrost for saftey reasons. We must be getting soft in the Ford section I didn't see any mention of blenders or razors blades you are a lucky guy And yes I'm getting tired of questions like this, didn't someone mention a "hardcore" Ford section once?
1sicbronconut is offline   Reply With Quote
Old 09-06-2008, 07:25 PM   #12 (permalink)
Member # 104850
http://fordtruckworld.tenmagazines.com
[B][COLOR="Yellow"]1987 YJ 60/14 on 40" ltb's [/COLOR][/B] :flipoff2:
SIKJEEP is offline   Reply With Quote
Old 09-06-2008, 07:30 PM   #13 (permalink)
mj
Member # 1919
Originally Posted by SIKJEEP View Post
ok that is the cruelest comment ever seen on p4x4
way to far there, Sir.
evil, just evil
Old 09-07-2008, 01:19 PM   #14 (permalink)
molson's Avatar
Member # 44912
thanks for the info on the vacuum lines by the battery....i have afeeling that i have a chipmunk that has gotten into the engine compartment..when i turned on the blower this morning i could hear a bunch of shit inside of the ductwork..more than likely the little bastard has done something...
thanks again...
and since no one has mentioned it, i'll go drink a shot of bleach
Old 09-07-2008, 02:05 PM   #15 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
thanks again...
battery acid makes the lines weak (along with heat) and they turn into play-doh.
Build thread:
Here
