spend money or deal with crap??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-14-2008, 02:50 PM   #1 (permalink)
Member # 121342
I am thinking about building a truggy out of a 89 f150 swb reg cab 2wd and using a 302, 2wd aod, transfer case to be determined, 9" rearend, and probably a wishbone 4wd hp 44 front.
What i am wondering is if it is worth using the 302 and aod or just find a whole new drivetrain? I could simply use the other 9" rearend or one of the 8.8s I have and find a complete new drivetrain. The only reason the 302 and aod is an option is b/c I have them and would only cost to modify but if modifying is going to cost even close to what another setup would then I would prefer to go with something else.
What do you guys think?
3day240sx is offline   Reply With Quote
Old 10-14-2008, 03:54 PM   #2 (permalink)
Member # 120345
I love 302's. But then I am kind of a goof ball. AOD's on the other hand, I think were a waste of metal. If the tranny is in good shape, run it. You can always swap in a C6 later. Build your truggy with what you have man... the mods to put in a Windsor and a better tranny when the time comes will be little to none.
Elwood is offline   Reply With Quote
Old 10-14-2008, 04:09 PM   #3 (permalink)
Member # 121342
I don't know much about the swap over from an aod to c6 mainly b/c I hate the aod's that much. Since I have to find a transfer case would it be better to get a junk yard c6 and t-case that is attached? I haven't dealt with this stuff in a few years so I don't know how hard it is to find the parts I will need.
I am guessing the shaft will be around 100 bucks to swap the aod to a 4wd setup and a c6 will be 100 to 300 and if it is 100 then it will end up having to be rebuilt which I can rebuild the clutches no problem but it still makes the price 300+ to get it done.
Seems like everything ends up the same price since I know this won't be done within the next year. I think I just talked myself into get a c6 and a t-case out of a junkyard and rebuilding it to go behind the 302. When time comes I can always go with a 400m in the place of the 302.
What ya think.
Old 10-14-2008, 04:29 PM   #4 (permalink)
Member # 120345
Ahh... wait... obviously I can't (or don't) read. I didn't realize the AOD was a 2wd... if it was me, I'd find a C6 with a transfer case attached. It's tougher and a hell of a lot easier to deal with.
Old 10-14-2008, 04:45 PM   #5 (permalink)
brewchief's Avatar
Member # 71185
I would take the time to find a c-6, preferably w/205, keep in mind that the 289, 302, 351W and 300 six use the small block bell pattern, the 351M, 400, 429, and 460 use the big block bell, and the FE engines use their own pattern. You need to decide what engine family you are going to use and match the trans to it.
Brewchief
brewchief is offline   Reply With Quote
Old 10-14-2008, 05:59 PM   #6 (permalink)
Member # 121342
When I put 400m I meant 351w with 400m crank and rods. Sorry for the confusion. I prefer a 300 I6 but they are hard to find and I have a 302. So from what I am reading throw the aod(2wd) away and find c6 and preferably 205 with a small block pattern bell housing. Thanks for the help guys.
Old 10-15-2008, 07:34 PM   #7 (permalink)
Member # 112640
[QUOTE I prefer a 300 I6 but they are hard to find and I have a 302. [/QUOTE]
Where do you live that you cant find a 300 Inline. There the most common engine in the ford f series in f-100 up to the f-250 till they were discontinued In the 90's.
edit: grammer
cumminstech_1 is offline   Reply With Quote
Old 10-15-2008, 08:37 PM   #8 (permalink)
Member # 121342
I looked within 100 miles of Memphis for 2 years and finally bought a whole truck running to get a good one. I was looking for a 87 to 92 fuel injected though.
Old 10-16-2008, 08:09 AM   #9 (permalink)
Member # 36399
A c-6 behind a 302....thats funnay.
Go 351W or go c-4. The c-6 will suck down 1/2 the power that little 302 has.
I LOVE 302's so it's not to bad mouth them, just I can tell a big differance between my 95 with a 4R70W, and my 94 with an Np435. I can only Imagine how much more power you would lose with a c-6.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 02-20-2009, 03:43 PM   #10 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
That's exactly what I have.
5.0/C6/203/toyota tcase
I really am getting annoyed at the non overdrive tho (it is in more of an expedition rig). Is there any easy way to bypass getting one of the $550 controllers for a 4r70W?? Is an AOD really that much of a money pit that I would waste more than $550 making it reliable?
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 02-21-2009, 07:52 PM   #11 (permalink)
Debauchery Wizard
BeefCakeScout's Avatar
Member # 80219
huh?where have I been?
Why can't they have gay people in the army? Personally, I think they are just afraid of a thousand guys with M16s going, "Who'd you call a faggot?"
Rock Goonies
BeefCakeScout is offline   Reply With Quote
Old 02-25-2009, 08:33 PM   #12 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
It's how the built strokers back in the day IRC. It got the job done, but you had to turn the crank down here and there to get it to fit. Not very strong compared to todays offerings either. Where things got schethy was when they ofset ground the crank for more stroke
masterbeavis is offline   Reply With Quote
Old 02-26-2009, 06:59 AM   #13 (permalink)
Member # 105656
Ummm. any auto will take away more power from a motor than a manual....
Are you refering to the TTB? thats what it sounda like to me... and if you are i would look for a strait axle if you are going to go over 35s.. don't get me wrong, i like to TTB, but only for a DD and mild off road..
hav24wheel is offline   Reply With Quote
