2.3L FWD Swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-02-2009, 04:03 PM   #1 (permalink)
HouseofDiesel's Avatar
Member # 106654
2.3L FWD Swap
How does the trans work? Can you run the trans to a divorced transfer case? Or do I have to use a 2.3 out of a RWD/4WD vehicle? I know the balancing is different so the motor has to be mounted the same direction, weather 90 Degree our regular. I also believe the bolt paterns on the blocks for the tranny's is different between the two because someone told me once that 4.6s have diff. paterns for the 90 Degree and convensional. Oh well early in planning so all the info you can give will help. If it can work I have a Ford Fusion thats totaled that I can bid on next week.
YouTube
thehouseofdiesel.com
Facebook
HouseofDiesel is offline   Reply With Quote Quick reply to this message
Old 01-02-2009, 05:51 PM   #2 (permalink)
Member # 115381
Send a message via Yahoo to fatboyf150
[COLOR="Lime"]What happens in the Cooking Forum, stays in the Cooking Forum.[/COLOR]
fatboyf150 is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 12:49 AM   #3 (permalink)
fume sniffer
rocklobster87's Avatar
Member # 122979
what in gods name are you blathering about
rocklobster87 is offline   Reply With Quote Quick reply to this message
