converting 5 lug hp d44 to 8 lug - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2009, 03:51 PM   #1 (permalink)
Member # 74475
What I have is a high pinion Dana 44 from a 77-79 Ford F150, and a Dana 44 TTB from an 82 F250. Can the hubs and/or rotors from the TTB F250 be swapped onto the solid axle D44's outer knuckles/spindles/etc? And yes, I know about the 8 lug conversion using Chevy parts, but figured I would ask if the Ford parts will work since I already have them.
Stevo
stevo is offline   Reply With Quote
Old 01-05-2009, 08:08 PM   #2 (permalink)
colbyhunt's Avatar
Member # 46719
Im not sure i have taken eight lug hubs spindle and brake caliper holders off of the front of a solid axle and put them on my five lug d44.
76 Bronco 42 pitbull rockers , tons, linked, co's
colbyhunt is offline   Reply With Quote
Old 01-05-2009, 08:10 PM   #3 (permalink)
colbyhunt's Avatar
Member # 46719
the more i think about i dont think it will work. The hubs off of the f250 ttb i have will not work on a d44 but will work on a d60. So i would imagine that the hub would also be different
Old 01-05-2009, 08:14 PM   #4 (permalink)
Member # 16545
i think you mean the d50 ttb not the d44 which was in most ttb f250's
canadian gunnut
Broncoo is offline   Reply With Quote
Old 01-05-2009, 09:33 PM   #5 (permalink)
Member # 74475
Yeah, the F250 I have has a Dana 44 in it.
Stevo
Old 01-06-2009, 05:58 PM   #6 (permalink)
Member # 74475
Back to the top, hoping someone specifically knows if the 3/4 ton TTB hubs and/or rotors will bolt onto the earlier 1/2 ton Ford solid axle.
Stevo
Old 01-06-2009, 09:14 PM   #7 (permalink)
mj
Member # 1919
have you tried the search feature, its a neat lil thing the sight owners put in to help find stuff that gets covered over and over
mj is offline   Reply With Quote
Old 01-06-2009, 09:20 PM   #8 (permalink)
mj
Member # 1919
http://www.pirate4x4.com/forum/showt...t=knuckle+swap
is that it?
Old 01-06-2009, 09:47 PM   #9 (permalink)
Member # 74475
Can you point out in that thread where it mentions whether or not the rotors/hubs will swap, because when I read that exact post two days ago when I SEARCHED for this information, it wasn't listed. In fact, the only thing listed in that thread that might be of any help is this:
Originally Posted by Dustball View Post
No, the 8-lug TTB 44 spindle has a different number of spindle studs.
...which doesn't address my question, considering I was asking about the hubs and rotors..
Stevo
Old 01-07-2009, 12:36 AM   #10 (permalink)
mj
Member # 1919
you have the parts
you tell us if they swap
dana docs dont show a part number for the hubs, they say contact Ford
rock auto lists an ACDelco hub that covers every year from 73-89
couple of hours you would know for sure by trying it.
post pics when you figure it out.
dana docs have 1979 f150
seal 35313
inner bearing set 706110x
outer bearing set 706111x
dana docs do not show a 1982 f250 so need a BOM to use,
I picked a few of them an 80 and 81 and 83
all used
seal 40709
inner bearing kit 706690x
outer bearing kit 706111x
Old 01-07-2009, 12:41 AM   #11 (permalink)
mj
Member # 1919
rock auto says the 79 and 82 F250 use the same rotor, raybestos 6084
and they say it is the same rotor used on the 1979 F350 4x4, and the same rotor on 1988 f350 4x4, 1995-1998 have a different number, slightly larger OD
Old 01-08-2009, 05:09 AM   #12 (permalink)
Member # 64075
The hubs and rotors will work from the ttb f250 but it will not mount on the 5 lug spindles nor use the stock calipers. 8 lug d44 hd used dual piston calipers. My advice to you is to get the outers off a 77.5-79 d44 hd (leaf sprung axle) knuckles out. It will be a bolt on swap.
Check out fullsizebronco.com search for 8 lug swap and it will give you all the part numbers, sites to purchase stuff, and more than ample Info you'll need.
1tonF100 is offline   Reply With Quote
