Member # 86651
NP-435 Grinding in first.
My early Bronco has a NP-435 that was running fine until I pulled it out to fix a leak. Like a dumbass I grabbed the output shaft and pulled it to get the trans out. The shaft and the bearing both slipped out about 1-2 inches and then slipped right back in. Now I've got everything back together and it all works fine but has a grinding noise when I use first gear.
So what did I fuck up? And how do I fix it? |
Member # 36399
First is a straight cut gear. It may make a whining noise, same with reverse. Now if it's actually GRINDING????
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks 95 F-150 6" of lift, SAS 35" BFG's |
Member # 86651
It never made this noise before I slipped the output shift out.
![]() While I had it out it fell off the floor jack and landed on it's side as well. It definately sounds like two gears are hitting each other. It only makes the noise when it is in first gear and the Bronco is moving. All other gears are fine and don't make any noise. Could the shift forks/gears have become mis-alighned or something? |
output shaft is also the main shaft. I am guessing when you pulled on it, you dropped the pocket bearings that go in back of the input shaft that the mian shaft rides on.
http://www.drivetrain.com/np435_p1.jpg
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home. |
Member # 86651
This diagram shows a "first-speed gear stop" on the mainshaft. Maybe that thing moved.
http://www.motorsport.wlrgroupco.com/np435fsmdiag.JPG |
#6 (permalink) | |
Member # 86651
Sounds like the damn thing will have to go to a rebuild shop. I aint got the coin for that right now. |
Member # 116651
You can always try rebuilding it yourself. A friend of mine rebuilt his for around $165 in parts. He isnt that mechanically inclined either and his holds up to his built 460 and heavy right foot.
79 F-150 302,np435, rest of the truck has been sold and is now retired. |
#8 (permalink) | |
you might be able to lift the main shaft from the pto cover or you might have to take off the shift cover to lift it. Remove the input shaft put all the bearings back in the pocket, use grease to hold them in. reinstall input shaft using the same shims that were behind the retainer.
Member # 6052
That would be my guess too. It's the lower left it looking at it from the rear if I'm remembering correctly. It's been a few years since I did the EXACT same thing.
'73 Bronco Growing pile of parts. 4 years is long enough! |
#12 (permalink) | |
Member # 86651
And thanks to Rockit for telling me which bolt to shorten, that saved me some time too. Now if I can just figure out my brake problem I can go wheelin! |
