Dual front tanks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2009, 12:34 PM   #1 (permalink)
Ak_F250's Avatar
Member # 39826
Dual front tanks
I had to ditch my rear tank when I shortened my frame, so Im down to the front ~20gal tank. Thats not really enough for a weekend wheeling trip, as I could burn both tanks plus a couple 5 gallon cans pretty easy before.
So I was looking at it last night, and I dont see any reason why I couldnt run another tank next to the factory one. Ive already redone the fuel lines and wiring, and left provisions for a second tank, so that wont be a big deal.
It looks like I would have to cut one notch in the rear body mount bracket for the front strap, bracket that holds the rear strap already has one.
The exhaust is rerouted, so its not a problem.
The fuel filler would be kinda wierd too, but it would still be better than 6 jerry cans.
Anyone seen this done before, or see any problems with doing it?
Dont let your rainbow haze cloud your judgment...I know More about alot of stuff most wouldnt think a gay guy would know...
Ak_F250 is offline   Reply With Quote Quick reply to this message
Old 02-17-2009, 06:14 PM   #2 (permalink)
Member # 17904
why not mount it on the opposite frame rail like Chevys do? possibly look into a bronco tank? I'm not familiar with your rig, so I'm only guessing.
HalfFastFord is offline   Reply With Quote Quick reply to this message
Old 02-17-2009, 07:44 PM   #3 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
As long as you won't have driveshaft clearance issues there should be no issues with putting another tank opposite the stocker, I'd definatley want to run one of the longer skinnier 19 gallon long bed ones, but, I don't see it being that much of an issue. Run the filler out to the pass side like an Older Chebby, and all should be OK.
Another option would be to mount a Bronco tank above he frame, one of my wheelin buddys has one in his Yota mounted that way, it works pretty slick, and it's about the same capacity as the pair of stockers on a F-Truck are.
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 02-17-2009, 08:51 PM   #4 (permalink)
Member # 85316
Send a message via AIM to svt150j49
arent the broncos 36 gallon? ive never had to fill my parts bronco tank.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi :eek:, 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread::evil::grinpimp:
The un-named buggy - 2.3L, lotsa tube, and FJ80s. :grinpimp:
svt150j49 is offline   Reply With Quote Quick reply to this message
