Member # 34889
C6 strong enough for Cummins?
I am looking to do a 12v swap into my 78 crew cab, I just had new drive lines done by jess and spent allot..
So I wanted to keep my c6 with married np205. Is there any thoughts on this. Can the tranny be reworked to have lower shift pts.. Thanks R I tried to search and nobody keeps the c6 for the swaps |
Member # 86524
WTF is with the cummins into fords all of a sudden? Granted its a great engine, but...
![]() Can the c6 even be adapted to a cummins (and not cost you more than the new drivelines you got)? If not, that saves you the research on the strength of the c6 ![]() EDIT: Or is this the same person as 12vbandit?
[URL="http://pirate4x4.com/forum/showthread.php?t=701511"][COLOR="Lime"][B]Build[/B][/COLOR][/URL]-1988 Bronco II 39.5"s and stuff [URL="http://pirate4x4.com/forum/showthread.php?p=13034565#post13034565"][COLOR="Lime"][B]TTB Dana 35 for sale![/B][/COLOR][/URL] Hello people, would you like me to murder you? I'm an offroad enthusiast! -Jeremy Clarkson Last edited by BigDusty; 02-20-2009 at 08:44 AM. |
Member # 34889
c6 to a 12v
Well the fact that a new rebuilt 351m will cost 4k to build and only put out 350hp and 450trq at 7 mpg
a 97 12v with 110k miles is $1800 at the yard and will get 20 mpg $200 worth of springs and plate work I can get 350hp and 550 trq And yes they make the adapters for cummins to c6 But I thought this was a ford forum and guys would know the Issues with the c6 thanks |
Member # 44308
I'd check fordcummins.com, even contact them as I'm sure they'd have some insight on the strenghts of a C6.
My gut opinion is Yes, enought strength if built for it.
No wheelin rig right now. 98 QCLB 4x4. Built 47RE, Bags, Guages, Pumped up, Exhaust, TW Guard Dog 35's, Ford knuckles/hubs. Looking for 1996 Ford Bronco 05 Dodge free-spin conversion /forum/dodge/880388-my-diy-2005-dodge-dually-4x4-5-9l-free-spin-kit.html |
I'd look for a C6 from behind a 6.9, from the factory they're set up with lower shift oints and more clutches than any other C6. The only thing that may be a PITB is setting up the VRV valve on the Cummins IP. The VRV regulates vacuum from the vacuum pump with throttle position so the vacuum modulator works the same as it would on a gas engine.
I'm sure that a C6 with a good torque converter would handle a Cummins no problem, but, the lack of lockup will suck.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... [URL="http://www.pirate4x4.com/forum/showthread.php?t=853402&highlight="]Build[/URL] |
