stripped chassis f350? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-17-2009, 12:26 PM   #1 (permalink)
Member # 41762
i bought a f350 for parts and i think it is a stripped chassis model because the rear dually is 68" wide. so i have an f250 2wd and want to swap the axles over and make it 4wd. so my ?'s are is this dually axle the same width as a 4wd single rear, and i also want to take off the front spacers to run normal rims do i have to find another high pinion axle or will any dana 60 work. thanks .
jeff ray is offline   Reply With Quote
Old 03-17-2009, 12:52 PM   #2 (permalink)
PsychoworkS's Avatar
Member # 130383
Cab and chassis frames are narrower and do not interchange. The spring perches are different widths.
I would stick with a HP D60 if I were you or else you'll run into front driveshaft-crossmember clearance issues.
Diagonally parked in a parallel universe.
PsychoworkS is offline   Reply With Quote
Old 03-17-2009, 02:45 PM   #3 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The front axle will work just fine with some SRW hubs on it, that's what I have in my junk. F250 Dana 50 hubs work nicely, and are easy to find.
I'm assuming the frame on your donor narrows at the back of the cab and is pretty much straight from there back?
For the rear, I just took the gears out of the cab and chassis axle and put them in my existing 10.25. I did measure it out, and IIRC, width was within an inch or so wms to wms, so moving the perches on the axle to suit could also work.
This is assuming you're working with an 80-97 F250 and 350.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is offline   Reply With Quote
