NP435 outputs?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-30-2002, 02:24 PM   #1 (permalink)
Member # 10622
NP435 outputs??
Rumour has it the NP435 has 2 lengths of 31 spline outputs. True / False
Also, how long is the adapter between the NP435 and T-case??
Is it the same for NP203 / NP205 / NP208, ect.??
'85 Bronco III
Rogue Bronco is offline   Reply With Quote
Old 08-30-2002, 04:20 PM   #2 (permalink)
Member # 8421
I was just talking to a guy this weekend who rebuilds manual trannies for a living (he wants to buy an NP435 that I have). He swaps them into Jeeps all the time. He said that all Ford 4x4 NP435's are the same.
Is this correct?
thecarman is offline   Reply With Quote
Old 09-04-2002, 05:55 PM   #3 (permalink)
Member # 5227
The only differences I know of are the 4x4 435's are 31 spline which are raised splines. The 2wd 435's are 28 spline. I think the 435 and T-18 are inerchangable but the T-18 is 1" longer, maybe that's what you mean by 435 4x4's are longer splines??????? 435's have an aluminum shifter cover and the T-18's are steel
A_Fahey is offline   Reply With Quote
Old 09-05-2002, 12:50 AM   #4 (permalink)
Member # 848
There are also 2 different input shaft lengths
SNOWTREK.org
Nobody is offline   Reply With Quote
Old 09-05-2002, 10:31 AM   #5 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Is this correct?
no, FOrd made more then 1
Mark
welndmn is offline   Reply With Quote
Old 09-05-2002, 10:37 AM   #6 (permalink)
Member # 10622
So what are the Differences?? input lengths, 28/31 spline, and......??
Are there two lengths of 31spline outputs ??
(I'm guessing NOT)
'85 Bronco III
Old 09-05-2002, 02:06 PM   #7 (permalink)
BnTMike's Avatar
Member # 197
there are 3 kinds of shift towers, I have seen 3 different outputs and 3 different inputs... big snout,standard, long and 31 spline output and long 28 and short 28 ... could be even more... dodge and chevy both used 435's
Mike-
LADD Racing #82 NCRR and 2014 KOH-EMC
Mike Ladd and co dawg Perry Hemre
Club Jackass Wheelers
TTC 1999
BnTMike is offline   Reply With Quote
Old 09-06-2002, 09:35 PM   #8 (permalink)
Member # 1481
i think there is more than one length. because i'll be damned if i can get my d20 to bolt up to the rear of my 435. i've cut about an inch off the output. just about fed up enuff to find a 205 that was mated to a 435 and say piss on the 20.
shon
researching my next mistake....
shons b2 is offline   Reply With Quote
Old 09-07-2002, 05:11 AM   #9 (permalink)
Member # 5227
Shon's,
The 435 you have should be a 28 spline and if the D20 you have is from a early Bronco it too has 28 splines. If you opt for a 205 you will need another 435 or an output shaft with 31 splines.
Old 09-07-2002, 08:12 AM   #10 (permalink)
Member # 1481
well, damn the luck. may have a line on a d21. thats what was behind my 435. i guess it'll do for now.
shon
