90 F350 and 84 F250 460 question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2009, 08:49 AM   #1 (permalink)
jimhat's Avatar
Member # 48475
ok forgive im a Ford newb, been workin on chebbys for 15 years.
so i have a 90 f350 with a FI 460 that is shot.
found an 84 F250 with a carb 460 in it that is almost brand new motor.
what all would i have to change to put the 84 carb 460 in my 90 and be able to put my FI on it?
Thanks
i already know i need to change all the accessories over to the 84 460 and the manifold but im not sure about if the manifold and old head will match up or what not.
jimhat is offline   Reply With Quote
Old 04-16-2009, 09:05 AM   #2 (permalink)
Member # 50971
the heads are different too the fi intake wont fit carb heads iirc
fordnut is offline   Reply With Quote
Old 04-16-2009, 09:51 AM   #3 (permalink)
jimhat's Avatar
Member # 48475
k ill have to see what shape the heads on my 90 are in.
will all the accesories and sensors from 90 motor go on the 84 motor or will have have to tab some holes in the 84 block?
Old 04-16-2009, 09:58 AM   #4 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The block is the same, the carbed engine will work quite effectively as a short block for you. I'm doing the opposite for my truck... You will lose a bit of compresion, as the carbed motor does have a bigger piston dish, but, I doubt the computer will care.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is offline   Reply With Quote
Old 04-16-2009, 10:27 AM   #5 (permalink)
jimhat's Avatar
Member # 48475
also what axles what the 84 f250 have under it?
