bleeding ABS module - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2009, 07:36 AM   #1 (permalink)
bremen242's Avatar
Member # 28687
bleeding ABS module
I was wondering if anyone has any trick to bleeding the abs module on a 2000 ford f150 besides getting a scan tool...?
I blew a line a while ago, and the master cylinder ran dry.. I got it bled but the pedal has never been great since then.
Fast Forward to yesterday....
I replaced a rear line and the brake hoses... master cylinder empty again.
I have it bled to the point it was at before (stops but not great), but I guess air in trapped in the abs module. The manual says you need a abs scan tool to cycle the abs while bleeding the brakes, but I don't have one.
any tricks to doing that, or should I just take it to someone who has a scan tool?
bremen242 is offline   Reply With Quote Quick reply to this message
Old 04-25-2009, 01:23 PM   #2 (permalink)
Member # 100050
I know this doesn't answer your question, but I was in a similar scenario. When I swapped the D44 into my ranger, my master ran dry. I thought I'd run into the same problem you have, so I just removed my ABS module completely. Brakes are rock solid.
96 Ranger-2012 4WOR Ultimate Adventure Invited Reader
Bray D is offline   Reply With Quote Quick reply to this message
Old 04-25-2009, 01:25 PM   #3 (permalink)
Member # 85316
Send a message via AIM to svt150j49
swing it by a shop with a scanner is the only way i can think of. They are a pain sometimes even with a scanner... good luck.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi :eek:, 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread::evil::grinpimp:
The un-named buggy - 2.3L, lotsa tube, and FJ80s. :grinpimp:
svt150j49 is offline   Reply With Quote Quick reply to this message
Old 04-26-2009, 07:22 AM   #4 (permalink)
bremen242's Avatar
Member # 28687
Thanks- I thought as much..
