B2 sas & 42's - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-20-2012, 12:13 PM   #76 (permalink)
bf
Member # 131367
bump for an update?
my 1994 Explorer build. superduty one tons, currently all leafs.
bf is offline   Reply With Quote Quick reply to this message
Old 07-19-2012, 09:28 AM   #77 (permalink)
Member # 125974
update...shoot its been awhile i guess huh, well ill keep it simple and a few pics, finally got my doubler installed last year, bought a hp 60 and put 538 gears in, did the 4.0 swap added a ladder bar to the rear, captured the front coils at top so they dont drop out, it is way more stable and predictable, rebuilt my front link mounts and did a flatbelly, and pretty much just been beatin the piss out of it havin tons of fun, the tranny is currently out so i can put a new clutch in tomorrow.
how she looks right now
you can sorta see the new link mounts doubler and ladder bar here...oops
heres the new link mounts flat belly addition
and heres a fun vid, no crawling but...
broncoruth rally - YouTube
86' BRONCO 2 sas 3 link, rock ram, full cage,538's, 42's, and trailreadys
RUTH is offline   Reply With Quote Quick reply to this message
Old 07-19-2012, 12:20 PM   #78 (permalink)
Member # 99058
that fawker looks stable.
Thought you were going to jump that pile o dirt lol
Fawk yea, redline that shit
Stranger ranger is offline   Reply With Quote Quick reply to this message
Old 07-20-2012, 06:53 PM   #79 (permalink)
Member # 157081
damn i thought this thread was long dead...
trusted_expert is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 11:12 PM   #80 (permalink)
Member # 125974
me too
Old 07-23-2012, 05:09 PM   #81 (permalink)
bf
Member # 131367
thx for the update ruth. your b2 is one that has given me inspiration for my explorer build.
Old 08-01-2012, 10:21 PM   #82 (permalink)
Member # 143596
What all did you do to support the radiator support? Im also going to use a toy ifs box and am looking for ideas on supporting the front.
87 Bronco 2, Lifted and stuff...
92blueoval is offline   Reply With Quote Quick reply to this message
Old 08-01-2012, 10:58 PM   #83 (permalink)
Member # 125974
i cut all the stock core support out and used 1 1/2 tubing to rebuild the fender mounts and radiator... for the ifs box i plated each side of the frame with 3/8 plate which may be overkill but i dont worry about it, also went with a trail gear hydro assist setup, which is super slow since i went with the bigger ram, if you want speed get the smaller ram...thats my next change
Old 08-02-2012, 08:01 AM   #84 (permalink)
DirtWorshiper's Avatar
Member # 81136
Bitchen, thanks for the update!
77 F-150 4x4, 92 Explorer 4D, 90 Ranger, 07 Rhino, & an 06 Dodge 3500 dually tow vehicle
DirtWorshiper is offline   Reply With Quote Quick reply to this message
Old 08-02-2012, 10:57 AM   #85 (permalink)
Member # 125974
well the last few days i have spent re-wiring this thing, ever since i did the 4.0 swap ive had both complete harnesses in this thing and sorta just spliced together... i started by removing all the stock 2.9 wiring for everything, lights, dash, gauges so all i had left was the 4.0 harness under the hood, then i took and eliminated all the lights and iother plugs not needed off the harness .... fyi, its a pita so last night i got pretty much done, havnt finished wiring tail lights or rock lights but went and tested it to make sure it was still charging and what not.. and tried to catch the full moon
Old 08-02-2012, 11:05 AM   #86 (permalink)
Member # 125974
few more randoms
Old 08-02-2012, 02:07 PM   #87 (permalink)
THEWHITEZOMBIE's Avatar
Member # 33502
sweet rig man, i watched all your vids lastnight Love your buddies rig too
Mike ECV 1849
69' Ford F250 Highboy 390FE/NP435/D24/HP44/D60
THEWHITEZOMBIE is offline   Reply With Quote Quick reply to this message
Old 08-02-2012, 02:54 PM   #88 (permalink)
Member # 143596
Can i get some pics of the tube front support? sounds like a much better route since i chopped the center of mine out to stuff the 5.0 in it
Old 08-02-2012, 04:33 PM   #89 (permalink)
Member # 125974
ill post the pic i have, you cant see much tho, in the picture the primered tube running from inner fender to inner fender is welded at those points and then i have a verticle support from the fram rails up, and at that same point on each side i have one more brace thats about a 45 degree angle that runs back to the frame by the coil buckets.. i just used little tabs to remount the grill and the radiator, o also for the radiator i welded in a suare tube between the inner frame rails to set the hight right with the fan on the engine.... hope that helps
Old 08-02-2012, 04:39 PM   #90 (permalink)
Member # 125974
oops no pic... one other thing, by welding the inner fender to that cross bar for the radiator which has the supports welded down to the frame, you need to solid mount the rest of your body, the front will have no body flex, it sorta becomes solid with the frame in a sense, or rubber mount your new front support.
Old 08-02-2012, 10:25 PM   #91 (permalink)
Member # 143596
Thanks man that helps alot, Ive got so many options and thoughts I'm still sorting out what the final outcomes will be, but im getting closer. Boxed the front of the frame tonight.
