c6 transmission build help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2009, 09:32 AM   #1 (permalink)
fordnut's Avatar
Member # 50971
first off thanks for any help. i am building a c6 trans for a f 150 on tons with a built 351w right now and id really like some pointers from those that have built these transmissions. ive searched but would really like some links to actual parts lists to build one of these up like ive heard like aod gear sets for lower first and second and whatever. ive built c4 before is there fancy servos and things needed . and help on definate parts would be great. also a quick break down on long and short factory c6 transfer case adapters. thanks
I dont remember what gears I had, but they barely fit in..
fordnut is offline   Reply With Quote Quick reply to this message
Old 05-12-2009, 09:39 AM   #2 (permalink)
Member # 27645
All the info you need is on this site or available on his dvds:
http://www.badshoeproductions.com/trans.html
Real trucks have the dimmer switch on the floor.
4XFORD is offline   Reply With Quote Quick reply to this message
Old 05-12-2009, 12:55 PM   #3 (permalink)
fordnut's Avatar
Member # 50971
some good stuff there gonna order video. anyone else . how about rear housings to t case seems like i have found a coupl different ones are any better than others?
Old 05-12-2009, 01:33 PM   #4 (permalink)
Member # 54844
there are two diffrent outputs for the 4x4 c6 - a long and a short - one is around 5" the other is around 7" that is it
and it is a e40d planet gearset - not the aod
how do you plan on driving it ? id get a e40d gearset and a good mild shift kit, aftermarket servo piston, run a deep pan - it should have no problem with whatever you toss at it
[SIZE="4"][COLOR="Red"]BSW[/COLOR] Racing, Super mod & [/SIZE] [SIZE="4"][COLOR="Navy"] Bitten [/COLOR]Off Road, Pro mod[/SIZE]
BSW Driver: Aaron Whitehead - Bitten Driver: Mike Stokes
BSW Spotter: Adam Kovarik - Bitten Spotter: Dan Kovarik - AKA -
: me fuckers :flipoff2:
build up of the truggy
f250rollinon37s is offline   Reply With Quote Quick reply to this message
Old 05-12-2009, 02:50 PM   #5 (permalink)
fordnut's Avatar
Member # 50971
that sounds like a good recipe thanks for the correction on the gears i have a few E40D i can take apart for the gears.
Old 05-12-2009, 05:45 PM   #6 (permalink)
Member # 126988
I needed a new valve body when i was rebuilding mine and i ended up getting the TCI StreetFighter valve body and I am very happy with it, it comes ready to bolt in and has the 'shift kit' setup that they put in their StreetFighter trannies. In D if i hold it on the floor it shifts 1-2 at 5300 rpm and chirps the tires. My 400 isnt stock though
wyazel1 is offline   Reply With Quote Quick reply to this message
Old 05-12-2009, 06:10 PM   #7 (permalink)
Hardcore Web Wheeler
Whitetrash303's Avatar
Member # 102426
There is always the poor mans shift kit. 16 penny's, 1/8" drill bit, 3 carbureter check balls. Also the little lever that applies band pressure has a letter code on it starting with "A" . A is the softest shift and it get's firmer as you go through the alphabet.
I did the 16 penny shiftkit and a "d" lever. It'll bounce your head off the back window if you're into the throttle hard.
Whitetrash303 is online now   Reply With Quote Quick reply to this message
Old 05-12-2009, 06:50 PM   #8 (permalink)
fordnut's Avatar
Member # 50971
sounds interesting got any more specific info on this poor mans mod
Old 05-13-2009, 08:51 AM   #9 (permalink)
Member # 20092
i run the art carr manual reverse pattern VB (off road style with compression braking) and it will chirp the 42s in the 1-2 shift. The E4OD gear set along with the roller thrust bearings is a great mod and goes a long way in reducing the internal drag. Ford Racing also sells a version of the E4OD gear set that has 6 pinion planets (I run this kit) for atomic bomb strength. I also run the E code shift lever and R servo.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote Quick reply to this message
Old 05-13-2009, 02:37 PM   #10 (permalink)
Member # 27153
Contact Jay at broaderperformance.com
He has a "book" that comes with modification instructions that I have Yet to find ANYWHERE on the net. Some oiling/shaft/pump/case mods. i got all my stuff through him.
Full rollerized C6, E40D low gear set, extra clutches in all the packs, servo mods, basically the 1,000 hp low gear low drag build all behind a 460.
How much you want to do ?
K&K Racing #21
ECORS Class A Early Bronco
broncman is offline   Reply With Quote Quick reply to this message
Old 05-13-2009, 03:12 PM   #11 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
Good advice. Imo, Jay Broader is THE man when it comes to C6s.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, 46" Titan R1s. Evil social media page link:
Proeliator is offline   Reply With Quote Quick reply to this message
Old 05-13-2009, 07:55 PM   #12 (permalink)
Member # 102426
I'll Post the poormans shift kit in a new thread so I don't hi-jack yours. Check it out
Old 05-13-2009, 09:13 PM   #13 (permalink)
Member # 64075
In my C6 I have E40d's planteries, kelvar bands, manual valve body, and a shift kit. check out monstertransmissions.com thats whom built mine.
1tonF100 is offline   Reply With Quote Quick reply to this message
Old 05-14-2009, 07:15 AM   #14 (permalink)
fordnut's Avatar
Member # 50971
sounds like i have a lot more reading to do now thanks guys , i cant wait to tear into this thing now
Old 08-30-2009, 10:27 AM   #15 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
Bringing this to the top, having never touched an auto tranny and not wanting to do it 5 times I am really looking for someone that knows how to build them in norcal (sacramento specifically).
It's behind a HO 5.0 with a 203/300 behind it, running 37's and it's not strictly for off road. I want it to be road friendly..
thx
This Space for rent!
Brandon is offline   Reply With Quote Quick reply to this message
Old 09-09-2009, 10:18 AM   #16 (permalink)
Member # 132654
I'm looking forward to this thread!!
Antiqueford is offline   Reply With Quote Quick reply to this message
