lift options for 1964 f-250 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-14-2009, 10:32 PM   #1 (permalink)
Member # 134505
its a 2wd ibeam front with front leafs, i'm wondering if all i need is lifted leaf springs and ubolts to lift it up?
truckcap22 is offline   Reply With Quote
Old 06-15-2009, 07:54 AM   #2 (permalink)
Member # 122566
thats all u need definetly
superd02 is offline   Reply With Quote
Old 06-15-2009, 08:03 AM   #3 (permalink)
Member # 94747
Get a leaf spring 44 or dana 60 and a divorced NP 205 and make it a 4x4. If its got the 292 and t98 4 speed your set that is a torque monster with a 6.XX first gear in the trany. My first vehicle was a 64. With stock springs and a SFA it will clear 35's and look sweet. Mine came with a semi float d60 in the back :thumbsup:
jr4x is offline   Reply With Quote
Old 06-15-2009, 11:26 AM   #4 (permalink)
Member # 134505
not looking to off road it at all so theres no need for the 4x4 with SFA, i'm just wondering how to lift it how it is. Would lifted chevy leaf springs work with bigger u bolts?
Old 06-15-2009, 01:30 PM   #5 (permalink)
can divide by 0
outfitter540's Avatar
Member # 101654
you are going to have to experiment, get some measurements and go to a pick and pull.
Ford with tires and wheels and shit...
outfitter540 is offline   Reply With Quote
Old 06-15-2009, 01:49 PM   #6 (permalink)
Member # 134505
so measure from shackle to shackle and find lift leafs that measure the same? but thats the basic concept correct? just leaf springs and bigger ubolts?
Old 06-15-2009, 04:23 PM   #7 (permalink)
can divide by 0
Member # 101654
you will need to fab ibeam drop brackets also otherwise you will have some sweet camber going on \ /
Old 06-15-2009, 05:01 PM   #8 (permalink)
jam0o0's Avatar
Member # 71891
don't forget longer shocks, longer/ redone steering links(not sure what that system looks like form memory)
don't forget to take the center pin location with you to the junk yard.
95 ford bronco, 351W - one tons, 38's, lockers, no discernible driving ability
93 F250, 7.3T, ZF5
jam0o0 is offline   Reply With Quote
Old 06-15-2009, 09:01 PM   #9 (permalink)
Member # 134505
i just got it running today it does have the 292 but its the 3 speed auto with the d60 out back
Old 06-16-2009, 05:21 PM   #10 (permalink)
Member # 132654
I made drop brackets on my 72 to clear 33's but I didn't get the geometry quite right, and I never got it aligned. It rode and drove like shit, but it definitely could have been done better. I used some 1/4" wall rectangular tube that fit in the original bracket, and used angle iron to brace it back to the crossmember. I don't know what can be done about the tie rod/ drag links though. prolly have to build your own. I lifted mine 3" and reused the stock shocks even though they were shot.
'72 ford f-250
[url]http://pirate4x4.com/forum/showthread.php?t=789549[/url]
Antiqueford is offline   Reply With Quote
Old 06-16-2009, 05:30 PM   #11 (permalink)
Member # 45530
why the hell are we discussing a 2wd lift that will never get wheeled on Pirate?
Panthers65 is offline   Reply With Quote
Old 06-16-2009, 06:29 PM   #12 (permalink)
Member # 134505
why the hell are you in my thread then? dont discuss it go on to your own troubles on here, there was no point in your coming in my thread and commenting on something that doesn't need commented on, so goodbye
Old 06-16-2009, 07:07 PM   #13 (permalink)
brewchief's Avatar
Member # 71185
How about you go fuck yourself and start a new thread on 2wdposertruck.com
brewchief is offline   Reply With Quote
Old 06-16-2009, 07:22 PM   #14 (permalink)
toy toyota
yotee's Avatar
Member # 20027
if it is a 64 then i think he is talking about a solid 2wd beam, think older
this is the best bad idea we have by far
yotee is offline   Reply With Quote
Old 06-16-2009, 08:10 PM   #15 (permalink)
Member # 45530
This is why cocksucker:
http://pirate4x4.com/forum/showthread.php?t=675729
You came to the forum, didn't read anything before, and posted dumb shit like that that has NOTHING do to with what this site is about. Go be butthurt on another site that deals with lifted 2wd mall crawlers
Old 06-16-2009, 08:16 PM   #16 (permalink)
GTOffroader's Avatar
Member # 34347
Send a message via AIM to GTOffroader
mall parking lot speed bumps count as wheeling bro!!!
89 FSB Mall Crawler
GTOffroader is offline   Reply With Quote
Old 06-16-2009, 09:28 PM   #17 (permalink)
Member # 134505
yeah so its not going to get wheeled because its all original antique, i'm going to lift it for looks how is that boring and stupid? find me a thread thats already covered this truck with this suspension on this site from a search, or else why cant i ask?
Old 06-16-2009, 09:39 PM   #18 (permalink)
Member # 45530
Missing the point there Ray Charles....
There won't be a thread like that because that is not what this site is for. Find a classic Ford site or a Ford specialty site, not an OFF ROAD, ROCK CRAWLING site....
Old 06-17-2009, 08:59 AM   #19 (permalink)
Member # 134505
exacty there wont be, because classic ford sites wont have any idea what a lift is, this site however does and everything is lifted so if you just want to be etuff and just try to look cool go start your own thread and argue with yourself i'm just looking for lift options for my truck thanks
Old 06-17-2009, 09:46 AM   #20 (permalink)
Member # 90667
First of all, Twin I beams have coils. Which do you have? Twin I- Beam or straight axle with leaves?
Gittinwidit is offline   Reply With Quote
Old 06-17-2009, 01:42 PM   #21 (permalink)
Member # 134505
its an ibeam front with shocks and leaves
Old 06-17-2009, 02:19 PM   #22 (permalink)
broncdawg's Avatar
Member # 42245
Calling the front axle I beam may cause confusion with folks who only know twin I beam. It's really a straight axle and can be lifted by simply rearcing your leafs. Depending on the lift you want, you may need a drop pitman arm to keep the steering geometry good.
Lot's of two wheel drives in the desert racing forum and if that's okay, why get all butthurt over this guys simple question??
77' Bronco,5.0 roller,Klune 4:1,37s,Wristed radius arm / 85' Runner-5.29s,Detroits / 79 F350 4x4
broncdawg is offline   Reply With Quote
Old 06-17-2009, 02:24 PM   #23 (permalink)
Member # 134505
alrigh thank you for your help brancdawg finally someone who just would answer my simple question instead of bitching about it thanks!
Old 06-17-2009, 02:33 PM   #24 (permalink)
can divide by 0
Member # 101654
I'm going to lift it for looks because I munch cawk
Fixed for accuracy
I was going to be a dick to you but decided to try and be helpful. I figured you were new here and didn't know how things go. So don't start shit here with some of the senior members because you WILL be forced to chug bleach.
Since it is an antique just leave it the way it is! Every one respects an unaltered vintage truck.
EDIT: Bronc- The 2wd pre runner types are cool, they go fast through the desert, they are custom engineered to handle some hardcore shit. A 2wd lifted for looks that will never see dirt is ghey.
Old 06-17-2009, 02:43 PM   #25 (permalink)
Member # 134505
lol its a farm truck that only gets used when something else breaks down, i would love to mudd it but since its my fathers baby i doubt he'd let me
