FI in 66 EB - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-10-2002, 03:50 PM   #1 (permalink)
Stallion's Avatar
Member # 61
FI in 66 EB
Want to go FI in my bronco. Found an '85 2wd F150 with a 5.0 and automatic tranny for sale with 170,000 miles. I would want to put my NP435 behind it. Is there anything wrong with this year FI, anything that would make me stay away from it? I have heard this will bolt right up to the np435, is that true?
brister101@hotmail.com
Stallion is offline   Reply With Quote
Old 09-10-2002, 04:10 PM   #2 (permalink)
Member # 3959
you'll need a body lift or hood bubble to fit it under the hood - if I remember correctly. The truck intakes are a bit taller than the car intakes. It will also be speed ensity, but as long as you don't make changes to the engine you will be fine. 170k is getting up there for a 5.0 though....
-Ben
'74 Bronco - some assembly required... one of these years I'll drive it again.....
When did common sense become uncommon?
injectedEB is offline   Reply With Quote
Old 09-10-2002, 06:53 PM   #3 (permalink)
Member # 1481
speed density is ok. just need to keep a cam grind that allows vacuum. loss of vacuum is what kills speed density. i thought ford went efi in 86??
up until 83 ford used the 435. if you have a 302, it will bolt to the 5.0(5.0=302=5.0) i believe only the upper plenum is taller on the truck. body lift or check around for a gt upper. corral.net is chock fulla parts!!!!
shon
researching my next mistake....
shons b2 is offline   Reply With Quote
Old 09-10-2002, 08:33 PM   #4 (permalink)
Member # 6708
FWIW; 1987 was the last year for the NP-435. My 1984 Bronco had the NP-435.
Eric
'There will be pork in the tree tops by morning!'-Lion in Winter.
'Dear,dear.....what ever shall we do with mother.'-Lion in Winter.
"Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson
'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!'
Alpo is offline   Reply With Quote
Old 09-10-2002, 08:42 PM   #5 (permalink)
Member # 1481
ok. i was told f-150's were 83. this was picked up when i was locating my bell to retain the slave cylinder for my clutch. not alot of room for mechanical linkage.
after thinking a little it makes sense. alot of 435 208 combos for sale.
shon
Old 09-11-2002, 08:04 AM   #6 (permalink)
Stallion's Avatar
Member # 61
I thought 85 was a little early for FI too, but that is what the guy said, (kind of a hard one to get mixed up, but you never know)! I am worried about the mileage also, I might just wait for something a little more appealing. I don't have a body lift, and don't really want to cut a hole in the hood, another good reason to keep looking! Thanks for the input!
Old 09-11-2002, 03:53 PM   #7 (permalink)
Hillbilly's Avatar
Member # 857
A buddy of mine had a 85 F150 that was FI. Maybe it was a late year run or something. I was always told 86 until I seen his. His dad was the original owner and I know it wasn't swapped in or anything.
Hillbilly is offline   Reply With Quote
Old 09-13-2002, 12:22 AM   #8 (permalink)
brocbronc's Avatar
Member # 3850
Get a 5.0 from a mustang 88-93. If you have 289,302 or 351 now with 435 the mustang will bolt up. Plus it will fit under the hood and have more power. I replaced my tired 351w with 93 cobra and everything bolted right up except clutch linkage and throttle deal. I think internal slave on clutch might work better. I kept mechanical linkage and had to tinker with it to make it all work.
69 Bronco, 72 Bronco, 66 vert mustang
I hate Smog certificates
brocbronc is offline   Reply With Quote
