7.3 Diesel-Excessive smoking - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-30-2009, 05:06 PM   #1 (permalink)
Member # 40162
Went and looked at a 93 F-350 Crew Cab Dually today. Has a 7.3 with a Banks Sidewinder turbo setup on it- supposedly only has 80K on rebuilt engine and turbo setup. The owner warned me that it would smoke, but DAMN it smoked horribly when revved up. Started OK with a jumpstart and shot of ether, ran a bit rough untill it warmed up a bit, then seemed to smooth out. The owner, like me, doesnt seem to know a lot about diesels, and was thinking the smoking was because of stale fuel due to the truck sitting for about a year with less about 1/8 tank- I think there is more to it than that though. It smokes a little at idle, and a lot when revved up. When it is warmed up, it subsides a bit, but is still pretty bad. Smoke is pretty much white, with a slight tinge of blue. I put my face right into the smoke as it was coming out the tailpipe and it had no recognizable smell to me- not oil or diesel- no smell at all really (but my sense of smell is'nt real great anyway) I read this thread
http://www.pirate4x4.com/forum/showt...ghlight=toilet
It gave me a few ideas- leaking injectors, bad turbo seal, or excessive oil buildup in the manifold from crankcase venting (can anyone be more specific on where to look for this oil build up??)
Seeing as the smoking of this rig is apparently worse than the one in the linked thread, can anyone give me some good advice on where to look first??
Guy wants $1000 for the truck, it is a rust free truck from Texas, already has a gooseneck ball in it. Unfortunately I could not test drive it because the auto tranny is bad- not so bad, as I want to put a ZF in it anyway. Truck has been parked for almost a year.
"Time you shut your cake-hole, YOKO!!!"
wyldstallyn73 is offline   Reply With Quote Quick reply to this message
Old 06-30-2009, 07:39 PM   #2 (permalink)
Member # 133721
sounds like it needs some glow plugs first. white smoke is usually unburned fuel. Since the truck needed ether to start it sounds like the glow plug system isn't working right.
Before that.
Ask him if he's treated the cooling system. If he doesn't know what cavitation is.... RUN lol.
itsacrazyasian is offline   Reply With Quote Quick reply to this message
Old 06-30-2009, 09:08 PM   #3 (permalink)
Hyde's Avatar
Member # 53554
Wow that was a great idea hittin a glow plug rig with ether, do that a few time and say goodbye to a rod. As for the smoke on startup they all do get used to it. Damn its been a while FA
A pile of parts 94 Explorer, 5.0, t18, np205, narrowed D44 and 9". Will never be finished
Hyde is offline   Reply With Quote Quick reply to this message
Old 06-30-2009, 09:28 PM   #4 (permalink)
Member # 128964
I had a problem like that on my 99...turned out the oil seal on the turbine side of the turbo went out. Check all the joints in the exhaut starting at the turbo. If you see oil seeping through the joints, that's your problem
tyson42 is offline   Reply With Quote Quick reply to this message
Old 07-01-2009, 06:55 AM   #5 (permalink)
Member # 52752
if ether was used on a regular basis you might have some nice blowby
bowtied_micky is offline   Reply With Quote Quick reply to this message
Old 07-02-2009, 07:20 PM   #6 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
Blow by is typical for the 6.9/7.3 at idle, and "should" decrease as the motor revs up.
masterbeavis is offline   Reply With Quote Quick reply to this message
Old 07-02-2009, 07:36 PM   #7 (permalink)
Member # 112640
You really mean smoke right. Blow by will never get better with rpm even on a new engine.
cumminstech_1 is offline   Reply With Quote Quick reply to this message
Old 07-02-2009, 09:45 PM   #8 (permalink)
Member # 125822
White smoke = unburned fuel due to dead hole (burnt valve rings?) smoke subsides when warm because it has enough heat in the motor to burn the fuel in the weak hole? Also explains why it runs smoother when warm.
dswhite is offline   Reply With Quote Quick reply to this message
Old 07-02-2009, 10:25 PM   #9 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
Blowby will decrease with rpm on a 6.9 due to the intake sucking it in through the cdr valve... LOL
White smoke is unburned fuel, could be from dead glow plugs(if it cleans up once it starts to warm up) worn/leaky injectors, or a bad injection bump. Odds are if it needs a sniff for cold starts, it's dead glows.
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 07-03-2009, 12:40 PM   #10 (permalink)
Hyde's Avatar
Member # 53554
Or a leak in the fuel system
Old 07-03-2009, 03:04 PM   #11 (permalink)
Member # 29794
Send a message via Yahoo to willys101_4lo
I think ya'll have all missed the forest for the trees on this one.
It's a rust free crew cab, with a running (although symptomatic) 7.3L with an add on Banks Sidewinder for $1000... You can part the bitch out for more than the sales price, esp if you jew the guy down to about $750. If its a 4x4 F350, its going to have a ball joint 60 front under it, which will sell for the sales price on its own.
Douche the sand out of your vag, buy the fawking thing with the understanding that if it turns out the motor is shit, you just part it out and make some money of the fawking thing.
[QUOTE=beater82;10834814]200,000,000 privately owned firearms in this country and you think we're gonna' run to your frozen ass nanny state to get away from that fuckin' socialist pimp? What the fuck do you think we are? Descendants of the french?[/QUOTE]
[QUOTE=Elwood Blues]Blessed Lady Of Acceleration, don't fail me now![/QUOTE]
willys101_4lo is offline   Reply With Quote Quick reply to this message
Old 07-03-2009, 04:47 PM   #12 (permalink)
Member # 40162
Its like you read my mind. I am in the midwest, so the rust free information is pretty pertinent- It is not a 4x4, but I dont want a 4x4 for a tow rig anyway- I have a 78 F-250 4x4 that I can fall back on if I ever feel the need to tow while also needing four wheel drive. I pretty much already decided to buy the thing when I went and looked at it due to the rust free body and the Banks turbo setup (even if it needs the turbo freshened up) I was just looking for info on what to start looking/working on once I get it home.
Old 07-03-2009, 05:13 PM   #13 (permalink)
Member # 29794
You always have the drastic option if it turns out the motor is too shot. Find ya a 12V cummins with an NV4500, drop that bitch in there, and you'll have a hell of a diesel truck.
Old 07-04-2009, 05:42 PM   #14 (permalink)
Diesel_Dirk's Avatar
Member # 106806
X2 I would pick that truck up in heartbeat.
my build:
Diesel_Dirk is offline   Reply With Quote Quick reply to this message
Old 07-06-2009, 08:21 PM   #15 (permalink)
Member # 138316
I own a 92 7.3, the injector pump on this motor has about 70000 mile life expectancy, they will still run but smoke...you can get longer life out of this pump if you use a fuel additive to lubricate internal seals. Best additive is Stenodyne (they make the pump) I use it every 3 to 4 fill ups and I have 357000 miles and still running on second pump changed @ 140000 miles. Hope this helps!!!
74bronco-okie is offline   Reply With Quote Quick reply to this message
Old 07-06-2009, 08:42 PM   #16 (permalink)
Member # 40162
Where do you get this Stenodyne??? parts store?? and what should it cost.
Picked up the truck today- he would only come down another hundred on the price, but I would have paid the full thousand anyway. Gonna have a friend that knows more about IDI's come over when he gets some time to get me going on this thing
Old 07-07-2009, 11:11 AM   #17 (permalink)
Member # 138316
Ford dealership, you will have to rebuild or replace the pump as the Stenodyne will only lessen wear not refurbish the seals. hope it works for you. I haven't bought it for a while cause last time I did, I got three cases and am still workin on them. Two years ago $14.00 per bottle that would treat 60 gal (every 3 to 4 fill ups).
Old 07-07-2009, 10:30 PM   #18 (permalink)
Member # 45125
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
And take a visit over to the IDI experts at oilburners.net
Adrianspeeder
08/02/74/66 F-250s, 97/79 F150s, 79/71 F100s
92/88/84 Broncos, 96/96 Exploders, 85 M1009
adrianspeeder is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 10:24 AM   #19 (permalink)
Member # 15263
For what it's worth, it's Stanadyne.
Oilburners is definatley the place for IDI tech.
Old 07-08-2009, 04:43 PM   #20 (permalink)
Member # 40162
Yep, been checking out Oilburners for a few days now- good stuff.
I tinkered with the truck a bit today. pulled the ductwork from the intake side of the turbo. The K&N conical filter was so plugged up that the suction from the turbo had actually started to collapse it Found a noticable sized puddle of oil in the gizmo that lets the crankcase fumes feed into the turbo inlet- looks kinda like a big EGR valve(whats the proper termionology for this thing??). Was some signs of oil in the turbo intake too. Also reached into the turbo and could detect some play in the shaft- I would assume that considering the speed at which a turbo spins at, there should be no play in this shaft, correct??
Old 07-10-2009, 02:58 AM   #21 (permalink)
alaskan goodoleboy's Avatar
Member # 63362
The injector pump is actually a stanadyne db2 pump and the life expectancy is minimum 70k out of the 6 idis ive owned only one had a pump that has replaced before 150k, the whole reason it was replaced is the bottom end gave out (19psi) and the motor was replaced. My old 85 F-350 had 500k with the original pump sure shes a bit loose, but it still starts up and runs good although she has a little smoke to her. Heres a link to stanadynes website and it will show you who sells the fuel addative. http://www.stanadyne.com/view.php?id=43
alaskan goodoleboy is offline   Reply With Quote Quick reply to this message
Old 07-10-2009, 09:48 PM   #22 (permalink)
Member # 91847
Based on the posts in this thread I am surprised no answer was forthcoming.
Does the truck start well cold but hard when warm? If so, with the heavy white smoke that would be a classic worn out injection pump. New pump will make a world of difference.
Turbo should not have much if any in and out play although a little side to side play is allright as long as the blades are not contacting the housing.
Good find by the way.
Dirtleg is offline   Reply With Quote Quick reply to this message
