The Donkey build.........#3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-21-2009, 06:14 PM   #1 (permalink)
montanatrout's Avatar
Member # 56693
I didnt think Blazer would ever get around to posting up any pics of his third build on his Donkey, quick history... (its called this because it started off as a 77ish F-150, then turned into kind of a truggy, then got most of a early Bronco body with a cage, now, its third build. Hence the name Donkey.)
We decided to totally rebuild the cage because we planned on building a tube rear. we went with 2x.120 crew. matching FOA coilovers will be soon mounted to the front hoops, but enough BS here are some pics..................
"America is at that awkward stage. It's too late to work within the
system, but too early to shoot the bastards."
'79 F-350 Crewcab, Cummins, 6spd. 37s
NPF chassis, 6.0, 4L80E, 404s, 42s,
NUKEPROOF FAB.
montanatrout is offline   Reply With Quote
Old 07-21-2009, 06:23 PM   #2 (permalink)
Member # 56693
Dare I ask for input from the pirate crowd?!
which is better? the spare tire parallel to the drive wheels, or perpendicular? Both look cool i think, the perp. way gives better departure angle, but parallel gives more room for the tool boxes, plus a little baja racer flavor. this way gives a little better visibility to the rear too.
NUKEPROOF FAB.
Old 07-21-2009, 06:25 PM   #3 (permalink)
Member # 56693
the tires on the truck are 42s and the spare is a 38x11. with the tire mounted parallel we could also fit a full size spare, where the perp. way we could not.
NUKEPROOF FAB.
Old 07-21-2009, 06:27 PM   #4 (permalink)
Member # 56693
more
NUKEPROOF FAB.
Old 07-21-2009, 06:39 PM   #5 (permalink)
Member # 56693
some vehicle specs............
-115" wheelbase
-about 5000lbs
-42x15 TSLs on stazworks double beadlock
-new 300 I-6 with TBI injection, and nitrous soon
-new C-6
-203/205 doubler with twin stick
-HP Dana 60 front, ARB, 5.13, 35 spline outers, warn premium
-14 bolt rear, 5.13, welded diff
-14 inch FOA coilovers in rear, 250/300 springs
-PSC hydro assist steering
-4 wheel disc brakes
-custom semi double triangulated front and rear suspension using 2x4x.120, poly bushing on frame end front and rear, and 2.5 inch weld in Ballistic joints in front, and the new bad-ass 3 inch Ballistic joints in rear axle end, 1" jonny joint uppers with 1.5x.120 DOM tube on top.
NUKEPROOF FAB.
Old 07-21-2009, 07:01 PM   #6 (permalink)
samoht517's Avatar
Member # 123360
That looks awesome im stealing some of those ideas for my future cage. Tire parallel looks better i think.
samoht517 is offline   Reply With Quote
Old 07-21-2009, 07:14 PM   #7 (permalink)
Member # 56693
tail lites and backup lites will go into the 2x4 tube on the cage overhead.
NUKEPROOF FAB.
Old 07-22-2009, 07:26 AM   #8 (permalink)
Old Ford Guy
4XFORD's Avatar
Member # 27645
Good lookin truck, should survive a rollover OK.
I like your choice of engine, most people think only in terms of rpm and hp. Torque and traction is what gets ya there.
Real trucks have the dimmer switch on the floor.
4XFORD is offline   Reply With Quote
Old 07-22-2009, 07:45 AM   #9 (permalink)
mtaylo21's Avatar
Member # 95068
Nice tubework....looks good!
mtaylo21 is offline   Reply With Quote
Old 07-22-2009, 08:56 AM   #10 (permalink)
broncdawg's Avatar
Member # 42245
Lot better visibility with spare standing up and the dezert look leaves room to mount tool box/cooler beside it. Damm nice build, glad you finally came around to the killer early bronco look!
77' Bronco,5.0 roller,Klune 4:1,37s,Wristed radius arm / 85' Runner-5.29s,Detroits / 79 F350 4x4
broncdawg is offline   Reply With Quote
Old 07-22-2009, 09:28 AM   #11 (permalink)
Member # 100397
Wow, looks very nice. I like the spare vertical like a standard spare. Great job.
Mild XJ - 8.8 rear, 4.5 RE lift, 37's nothing too special, just a cheap wheeler!
zdaily is offline   Reply With Quote
Old 07-22-2009, 05:23 PM   #12 (permalink)
Member # 40162
That is probably the best looking rear tube job I have ever seen. Thumbs up on the engine choice too!!
Definitely mount the spare parallel.
"Time you shut your cake-hole, YOKO!!!"
wyldstallyn73 is offline   Reply With Quote
Old 07-22-2009, 07:48 PM   #13 (permalink)
jam0o0's Avatar
Member # 71891
lay the spare down and put the cooler on top of it.
cage looks good (not finished i'm sure).
did you really use .125" wall for you lower links? that seems kinda way to thin.
at least with the big 6 you'll have plenty of room to work on it. lol
95 ford bronco, 351W - one tons, 38's, lockers, no discernible driving ability
93 F250, 7.3T, ZF5
jam0o0 is offline   Reply With Quote
Old 07-23-2009, 06:08 AM   #14 (permalink)
Member # 56693
I definitely agree, parallel is were is at.
"did you really use .125" wall for you lower links? that seems kinda way to thin."
as far as 2x4x.120 for the lowers. I have been running mine from the same size for almost 5 years with no issues. sure they have a few small dents in them from bashing a rock or stump, but they are a superficial. there is no compromise in strength as the dents are so small. I built a pair for the 2LIVCRW (6500 lb. crewcab on 47s) out of .188 but even that was way overkill in my opinion. The strength is in the structure of the 2x4, you coulnt bend em!
NUKEPROOF FAB.
Old 07-23-2009, 06:23 PM   #15 (permalink)
Member # 128238
Thats intense, great tubework man.
LegendKiller89 is offline   Reply With Quote
Old 07-24-2009, 07:29 AM   #16 (permalink)
wheelin66bronco's Avatar
Member # 44308
Build. Scrap it and start over
No wheelin rig right now.
98 QCLB 4x4. Built 47RE, Bags, Guages, Pumped up, Exhaust, TW Guard Dog 35's, Ford knuckles/hubs.
Looking for 1996 Ford Bronco
05 Dodge free-spin conversion /forum/dodge/880388-my-diy-2005-dodge-dually-4x4-5-9l-free-spin-kit.html
Originally Posted by broncolou View Post
LS motors are like tampons....every VAG has one!
wheelin66bronco is offline   Reply With Quote
Old 07-26-2009, 07:22 AM   #17 (permalink)
Member # 87852
Nice build... Let's see some more pics!!!!!
I also say parallel for the spare tire!
Mud-Nut is offline   Reply With Quote
Old 08-08-2009, 12:36 PM   #18 (permalink)
Member # 56693
right back at ya! bitch!
NUKEPROOF FAB.
Old 08-08-2009, 07:47 PM   #19 (permalink)
Member # 128238
Why scrap it?
Old 08-10-2009, 02:30 PM   #20 (permalink)
Member # 56693
this is what we came up with for the tank and battery, i think the tire will end up laying flat on top of the batt.
and we burned some magnesium dust for jake cutting down his runflats for the H-1's....................that shit burns as bright and welding arc!
NUKEPROOF FAB.
Old 08-10-2009, 03:35 PM   #21 (permalink)
Member # 125848
I was reading through it and I was just about to ask where you were going to mount the tank and stuff then I saw your last post. That looks pretty bad ass, I like it a lot. Those motors have lots of torque too. I like the choice of motor, you don't see people use those a lot but they are good motors and will run forever. Keep the updates coming!
98ZJ is offline   Reply With Quote
Old 08-24-2009, 09:50 AM   #22 (permalink)
Member # 56693
update......gas tank in, 1 ammo can on each side of tank, 38x11 spare tire flat on rear, front winch mount for 8274, rear tow point, shitty front shocks, radiator, roof, cage pretty much done.
NUKEPROOF FAB.
Old 08-24-2009, 09:24 PM   #23 (permalink)
WeX
WeX's Avatar
Member # 102801
Freakin Awsome MAn
WeX is offline   Reply With Quote
Old 08-25-2009, 11:03 AM   #24 (permalink)
Member # 56693
see the integrated fairlead
NUKEPROOF FAB.
Old 08-25-2009, 02:47 PM   #25 (permalink)
jtr
In the garage
Member # 41068
Blaze is sticking some cash into that thing. Nice work Chris!
Tow rig build: 1997 F350, Powerstroke, 4wd conversion
Crawler build: 1990 Ford Ranger Truggy
Daily driver build: 1965 Chevy
jtr is offline   Reply With Quote
