Member # 1919
anyone done a hydro clutch conversion on a late 70s ford?
I think the pedal side looks pretty easy but the bellhousing side is a mystery. 1- is there a hydro throwout bearing available for the np435? 2- is there a factory external bellhousing for the np435 behind an M that I can hunt for in the wreckers? 3- any links to well done conversion appreciated. |
Member # 92901
I beleive you could probably use one like this on the right. It came off of a t-19 that was behind a diesel in a 84 f250.
If you want more pictures of the slave cylinder I can get them for you.
77 Scout SSII 460/c6/np205 Dana60/14blt Artec 3link front and 4link rear |
Member # 1919
diesel bell has a different pattern from what I have read
I have read on other forums there was some depth differences in the 460 version from the M, I take it as unproven cause it wasnt on here subject to real scrutiny ![]() thanks for the image |
Member # 17313
If you look at the stock setup for a small bolck hydro clutch bracket, its pretty easy to replicate. two of my buddies have done this for M bellhousings, to swap 400's into 90's trucks, however I have no pictures..
I did mine a bit different... As I used a M bellhousing behind my 90' 460, which needed a 1/2" spacer to make the bellhousing fit. When I made the spacer, I made a tab stick out from it long enough to later torch out for the slave bracket. ![]() Here you can see it mounted up, I also welded part of the old small block slave bracket on to it, for the clip to hold on to.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 1919
http://www.cncbrakes.com/sc.asp?grp=...305&subseries=
anyone tried these? ID is a bit smaller then factory ford stuff but mounting looks easier any P4x4 vendors for CNC stuff? |
#8 (permalink) | |
Member # 9152
About the master cylinder: be sure you reinforce the firewall with a plate inside of where you mount it. This is important.
Why kill them with kindness when you can use an axe? |
