Member # 54152
Bell housing. Diesel and 460 same?
Lookin at the 5 speed in a mid 90s ford. Has a diesel, Didnt look to see if it was the 6.9 or 7.3. Not even sure if they were both options for those years but wondered if that diesel bell housing was the same for a 460? Thats what ide like to use it for..
2008 F250 CC SB Lariat 4x4. 700HP on fuel. 93 F150. 01 F350. 97 Ram 1500. |
Fawkin Fordhead
The patterns are not the same, the lower 4 boltholes and the dowel pins are located differently, and the diesel bell doesn't have the holes for starter mounting.
You can drill it to suit, it can and has been done, but, I definatley wouldn't reccomend that. Also, the diesel transmissions have a 3.79 or 4.14 first gear, depending on the year, where the gasser trans will be 5.72
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
There are two versions of the ZF, the S5-42 (1307 casting) and the S5-47 (1317 casting) that will fit 3 different families of motors. The 47 I think will handle more torque(470# rating over 420#) and (maybe) has an internal throwout slave thingermabob. Diesels are close ratio, 4.14:1(S5-42) (5.08 S5-47), gassers are 5.72:1
This is a diesel trans with a 460 spacer.
#6 (permalink) | |
Member # 140580
1996 DODGE 2500, 4X4, CUMMINS, 370'S, 5GSK, MACK PLUG, STUDS, SFI FLEX PLATE, DERALE DEEP PAN, EMS HUB KIT WITH 35 SPLINE INNER AND OUTTER MOSER AXLES, WARN GOLD LOCK-OUTS, 3 IN. LEVELING KIT, DUAL EDELBROCK REMOTE RESERVOIR SHOCKS, ROUGH COUNTRY STEERING STABILIZER, STEERING BOX BRACE.
Member # 54152
The bell housings on the 5 speed models do not seperate from the tranny like the older 4 speed units do.
#10 (permalink) | |
![]() http://pirate4x4.com/forum/showthread.php?t=653324
Member # 47300
sucks, i was hoping to get the lower gear in my diesel when i swap a zf5 into it. Thanks for the info guys.
83 chev pickup LPG350/400/208 on 10b/14bff on 37 iroks |
