Narrowed Fullsize? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-25-2009, 03:49 PM   #1 (permalink)
can divide by 0
outfitter540's Avatar
Member # 101654
Narrowed Fullsize?
I did a search and only found a couple pics of some front narrowed foolsizes. If you have some pics I would like to see them as I am looking for ideas. Thanks
Ford with tires and wheels and shit...
outfitter540 is offline   Reply With Quote
Old 08-25-2009, 04:23 PM   #2 (permalink)
Member # 26394
Good luck, depending on what year model they can be hard to do.
78 Bronco, 4" lift, 2" body lift,42" TSLs, KORE Beadlocks, 4.88 gears, 14 bolt with detroit, HP60 front welded, Psycho Fab doors, High Angle rear driveshaft, Warn HS9500
broncofreak2000 is offline   Reply With Quote
Old 08-25-2009, 06:59 PM   #3 (permalink)
Member # 56006
Theres a fullsize 79 Bronco that has been posted on here...Ill see if I can find it...
EDIT: TADA!!!!!!!
http://poorboy1.proboards.com/index....ad=4268&page=1
[QUOTE=Sturgell;9689430]Would you rather suck a dick or make out with a dude?
Myself I would have man up and suck a dick, pretty sure I couldn't make out with a dude.[/QUOTE]
JoshTurner is offline   Reply With Quote
Old 08-25-2009, 10:21 PM   #4 (permalink)
Member # 99527
i helped build that bronco it was cut up the middle with 18" taken out of the center, even the dash and tail gate
popeye123 is offline   Reply With Quote
Old 08-25-2009, 11:38 PM   #5 (permalink)
Member # 56006
I love that Bronc... 1 of my faves
Old 08-26-2009, 11:38 AM   #6 (permalink)
Member # 85036
The "Carcass", a skinned, narrowed, bobbed, exo-ino caged, boatsided, 1990 Bronco.
3 tons of fun!
There are many more pics at Supermotards link below.
Da "Carcass"
Built by Swat.
[url]http://www.supermotors.net/vehicles/registry/3612[/url]
Blown349 is offline   Reply With Quote
Old 08-26-2009, 11:46 AM   #7 (permalink)
95steel's Avatar
Member # 14509
Gov't mule was full size that had a few inches cut out of the middle, think it was 4 or 6 inches... been a long time though.
95steel is offline   Reply With Quote
Old 08-26-2009, 09:41 PM   #8 (permalink)
MASTER TECH
f250rollinon37s's Avatar
Member # 54844
mines missing a bit in the front too
BSW Racing, Calrocs Super mods 12 & ?
Driver: Aaron Whitehead - Driver: Joe Hutchins
Spotter: Adam Kovarik - Spotter: Dustin Knight
Crew Cheif: me fuckers
build up of the truggy
/forum/ford/544813-update-pics.html
f250rollinon37s is offline   Reply With Quote
Old 08-27-2009, 08:13 AM   #9 (permalink)
Member # 85036
My rig is 5 inches narrower at the bottom of the door sills. I gained that much by removing the doors and cutting the door jamb back. I then boat-sided it and gained much more clearance down low. It now has 23" of clearance at the belly and I am only running about 5"s of lift with 40" tires. Cutting off fenders and tubing it up made for great tire clearance and allowed me to lower it two inches.
Da "Carcass"
Built by Swat.
