need advice on waganeer springs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-19-2009, 10:22 AM   #1 (permalink)
Member # 144540
i used the stock 3/4 ton springs for mockup and the virgin run but i just got a free set of used wagoneer springs and im gonna use the rear wagoneer springs up front, is any one running these ?if so how many leafs are you running?
thanxs
sasexplorer is offline   Reply With Quote
Old 10-19-2009, 11:00 AM   #2 (permalink)
Member # 112214
I am using a 7 leaf pack from a Wagoneer on my SAS Sport Trac. I also used the front waggy springs with the offset center pin. However the drivers side is a little weaker for some reason.
02 Sport Trac SAS D44
chad551 is offline   Reply With Quote
Old 10-19-2009, 11:32 AM   #3 (permalink)
Ford Bigot
FordFascist's Avatar
Member # 31227
Rear Wagoneer springs are the same dimensions as a stock 2WD F-150, so they are way too long for a front end application IMO. I run them on the rear of my EB and they function well in that application.
You are looking for front Waggy springs in the 7 leaf variety which function pretty well. I'm running the front 7 leaf springs in my GPW and have had great luck with them.
Originally Posted by MtnYota
It sucks I took a dump earlier, now I'll never know if that roll would have caused me to crap my pants
Project Flat F***er (Fender)
Project SR5.0
FordFascist is offline   Reply With Quote
Old 10-19-2009, 06:14 PM   #4 (permalink)
Member # 144540
spring
my friend used rear f150 2wd springs up front of his explorer i was just wondering if i should take the overload out and leave 4 leafs
Old 02-01-2010, 07:15 PM   #5 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
Is the offset the same?? The wagoneer rear springs are a waaaaay to soft, I need something a bit stiffer (I took a leaf out, and lost it )
Another complete set might be fine but it had a bit o arch, maybe the 150 is a bit less arch?
This Space for rent!
Brandon is offline   Reply With Quote
