1961 ford f350 dually 4x4 project - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2009, 08:33 AM   #1 (permalink)
Member # 144284
Hey I'm new to the forums but I'm in the process of making an off road mud eating truck out of my 1961 Ford f350 dually 292 y block 4 speed. I plan to make it for every purpose rock crawling, trails, snow, mud, and highway... I'm only 15 and its a good projectbut it hasn't moved or ran in 36 years. I got it for free. I got the engine unfrozen. I plan to convert it to four wheel drive. I got a free Dana 60 from a pick and salvagenow I just need to get a transfer case and shaft. Is there any transfer case u guys recommend? I want to do a diesel swap later in the years, but that 292 y block is awesome. im going to do a flatbed.. YouTube - 1961 ford f350 dually pt2..
mendo707 is offline   Reply With Quote
Old 10-24-2009, 08:48 AM   #2 (permalink)
Member # 116277
Send a message via AIM to purecountry Send a message via Yahoo to purecountry
I tried once, so now you can have fun. You basically just got dropped into the general population at prison. I would suggest you start using spell check and proper grammar and your life here on pirate will be much easier. Most people won't respond, or will respond with constant flaming if your post looks like it was written by a two year old.
[QUOTE=nahmus;10554695]
this country is trying to childproof the world when they should be worldproofing their children.[/QUOTE]
[QUOTE=SilverZuk;10606373]My wife doesn't go out, but if she did I would piss on her and kick dirt all over her before she left.
[/QUOTE]
purecountry is offline   Reply With Quote
Old 10-24-2009, 09:02 AM   #3 (permalink)
can divide by 0
outfitter540's Avatar
Member # 101654
Honestly it doesn't look as bad as most of the n00b posts made by people a lot older than he is.
The "easy" way would be to use a divorced 205 transfer case with a custom cross member. That way you don't have to fool around with swapping transmissions. When you do your diesel swap you should look for a complete setup: engine+trans+tcase. Or you could just swap the diesel in now and forgo the 292 to save you some work?
Ford with tires and wheels and shit...
outfitter540 is offline   Reply With Quote
Old 10-24-2009, 09:12 AM   #4 (permalink)
Member # 144284
Thank you.. yeah im going to get that 292 y block running.. Just need too get a divorced 205. What kind of vechile whould that be on?? Thanks
Old 10-24-2009, 09:18 AM   #5 (permalink)
Member # 116277
A 73-77.5 Ford F-250 High Boy truck will have a divorced 205. If you can find one complete, and steal the front axle, transfer case, front springs and all out of it, you'll be much better off in the long run. Hell, find one with a trashed body, and buy the whole truck at scrap price, you'll be happy you did when you need that one last piece to finish the truck.
[/QUOTE]
Old 10-24-2009, 09:24 AM   #6 (permalink)
Member # 144284
[QUOTE=purecountry;10485902]A 73-77.5 Ford F-250 High Boy truck will have a divorced 205. If you can find one complete, and steal the front axle, transfer case, front springs and all out of it, you'll be much better off in the long run. Hell, find one with a trashed body, and buy the whole truck at scrap price, you'll be happy you did when you need that one last piece to finish the truck.[/QUOTE
Thanks I will go to the salvage yard and see what I can do..
Old 10-24-2009, 09:41 AM   #7 (permalink)
Member # 123663
I wouldn't do anything with that y-block, I love those motors just because of their cool factor but they are pretty strung out and expensive when they get past the 400hp range. Find a good cheap 460 and swap it in there or just do the diesel swap now. I wouldn't throw money at a motor you arn't going to use.
1966Tbird is offline   Reply With Quote
Old 10-24-2009, 09:46 AM   #8 (permalink)
Member # 144284
Yeah i want to try to get it running. but if its going to be a pain its out of there.. thanks how much are those stock 292, torque and hp running at???
Old 10-24-2009, 01:01 PM   #9 (permalink)
Member # 6708
you have the big opening front fenders, DONT get rid of them, they are not too common, and will allow larger tires in the future without hacking the fronts. The F-250 4x4 from as far as I can tell has the same frame and definatly the same cab. this is true for 1961-1966. the T-case from those years are a divorced style, Dana/Spice model 24. good/strong case and since no one wants them, might be even cheaper than a NP-205. but you should be able to use a NP-205 also without any problems. the Dana 24 was used thru 1972. the Np-205 from '73-77 1/2 in divorced. The cross member that the t-case bolts up to via adaptor plates may even already be bolted into the frame.
That bed might be good for someones Expedition Vehicle. fully enclosed bed with windows, very cool. but looks heavy has hell.
A D-44 or D-60 thru 1979 might have the same spring center-center distance. will make bolting in easier. should be good from 1961-1966 at least.
'There will be pork in the tree tops by morning!'-Lion in Winter.
'Dear,dear.....what ever shall we do with mother.'-Lion in Winter.
"Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson
'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!'
Alpo is offline   Reply With Quote
Old 10-24-2009, 01:05 PM   #10 (permalink)
Member # 144284
Thanks dude that helps me a lot.. i will check it out about the dana and transfer case.. how do u know all of that stuff about that truck
Old 10-24-2009, 06:05 PM   #11 (permalink)
6gun's Avatar
Member # 95448
Where You live
I am getting ready to clear out some Ford stuff. If you are close we can get together, I would rather see the stuff go to new guy a youngun that will use it.
6gun is offline   Reply With Quote
Old 10-24-2009, 09:37 PM   #12 (permalink)
Member # 130328
i'm curious about the box on the back. could you get some pics before you get rid of it.
thanks
joshua
70 Olds 442 68 Chevy Longhorn 05 Honda CRF450X SM
99 F250 4X4 totaled PS with 6spd for sale soon
supersweet442 is offline   Reply With Quote
Old 10-25-2009, 05:50 PM   #13 (permalink)
Member # 6708
I used to own a '65 and a '66 F-250 4x4. in those years, they shared ALOT of the same stuff from the F-350. Same style of motor mounts (nose cradle/two ears on the bell housing w/tranny hanging in the air), same cab with battery in the floor and steering gear/colum. Can also look at f-100 4x4 from 1961-1965. Do not look at a 1966 f-100 4x4. they are coil sprung and no longer used the 120 inch wheel base frames. the cabs used for 1966 f100 was the 4x2 set up. why the F250 still used the F350 frame in '66?? dunno, last swan song before everything standerdized in 1967 I suppose. But the f-250 4x4 was still unigue in frame width thru 1977 1/2 when the lower front ends went into production.
Old 10-25-2009, 06:10 PM   #14 (permalink)
Member # 144284
sweet.. I live In ukiah ca
Old 10-25-2009, 06:20 PM   #15 (permalink)
Member # 144284
yeah i will do that 4 you... check out my other vid on youtube bettter view of it
Old 10-25-2009, 06:21 PM   #16 (permalink)
Member # 144284
Thanks for that great informathion.. i will check that out
Old 11-20-2009, 09:49 AM   #17 (permalink)
Member # 146692
Hello...Love the heavier trucks of this era...plenty of other people do also. :-) Please be sure to check out www.slick60s.org. We are a pretty well known group of 1961 to 1966 Ford truck nuts that are always looking for another "Slickster"(you'll get that if you check us out) Consider this my invitation to join our forums and find out more about your truck than you ever thought possible.
Cam
P.S. If you decide to join...we have chat every Sunday night @ 8PM CST till whenever.
semotrucker is offline   Reply With Quote
Old 11-20-2009, 11:10 AM   #18 (permalink)
Member # 73465
Damn... That is an UGLY Truck. I LIKE it. reminds me of me.
Like someone here has already said, buy a junker 73-77.5 F250 4x4 for use as the donor. You will get 99% of the running gear you will need, and a lot of optional parts that will make life better (easier), like misc. wiring, nuts and bolts, the little crap that adds up and you won't have to source elsewhere.
Good luck, and don't give up on 'er.
Got Ford?
3 Early Broncos, 2 Classic Mustangs, 68 F100, 71F250 4x4, 2 Lincoln Mark VIII - BF Penn
[QUOTE=nahmus;10554695]This country is trying to childproof the world when they should be worldproofing their children.[/QUOTE]
71PA_Highboy is offline   Reply With Quote
Old 11-20-2009, 02:29 PM   #19 (permalink)
Member # 83657
Since your going to beat on it you should sell me the front fenders. Lmk If you would be interested I sure could use them.
brent460 is offline   Reply With Quote
Old 11-21-2009, 06:49 AM   #20 (permalink)
Member # 144284
fenders are going 2 be the same, no cuting
Old 11-21-2009, 06:49 AM   #21 (permalink)
Member # 144284
yea shes a ugly one but when im finished. its going 2 be sweet
Old 11-21-2009, 05:29 PM   #22 (permalink)
Member # 83657
Not trying to swindle anyone out of there parts Im wanting to do a resto mod on my 66 short bed. I really want a set of those front fenders. I just figured if hes going to dent it up he might just make some extra money on the fenders and trim up a set of half ton fenders. Good luck on the build btw itll make for a sweet truck.
Old 11-22-2009, 10:31 AM   #23 (permalink)
Member # 144284
yeah im not going 2 hert the fenders they are 2 pretty.. lol
Old 11-22-2009, 10:41 AM   #24 (permalink)
Member # 144284
Cam
i joined thanks 4 the great website.. my account name is ebentraywick
