Member # 142280
bummer, almost GUARANTEED to be an EGR cooler. The water/fuel drain is on the left frame rail below the drivers door on the inside. It takes a 6mm allen wrench to get it out. Most likely not your problem. You have water in the cylinders from the egr. Most likely, if you start it, let it idle for a minute or two and then rev it up slowly and keep it at a higher idle for a little bit it will clear up. Still need to replace the EGR cooler though. Also, there is a TSB that wants you to service the oil cooler with it. Are you still under your 100k miles? If so, its a warranty repair.
*EDIT* It may also have stuck EGR valve. usually causes black smoke not white though.
"I've learned that you can get by on charm for about fifteen minutes. After that, you better have a big willy or huge boobs" Last edited by Idaho Hillbilly; 12-27-2009 at 12:01 PM. |
Member # 104270
yeah white smoke is usually caused by water/coolant in the cylinders.
Fueled by Hate, caffeine, and sometimes whiskey. My Junk. http://www.pirate4x4.com/forum/showt...229&highlight= |
