Member # 127099
7.3 idi exhaust recommendations
I have a 1993 f350 dual with the 7.3 idi diesel (tow rig) I’m looking to put exhaust on it so it sounds half way descant any recommendation and my question is what kind of back presser do I need to keep and or none and what muffler? Thanks
Fawkin Fordhead
Backpressure is your enemy on a diesel, Ford really restricted the exhaust on the IDI's compared to IH apps, IH ran 2.5" duals off the manifolds, stepped to 2¾" before the muffler, and a 4" tailpipe out of the muffler, where the Ford system is single 2.5" throughout.
Pretty much any muffler will sound the same as it will on a big block, only with extra rap due to the compression ratio. However, any muffler you cannot see through will raise EGT's, especially those of the chambered variety.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build Last edited by 82F100SWB; 01-21-2010 at 04:00 PM. |
Member # 141697
Your best bet is to run a muffler with as little restriction as possable. On my 7.3 idi im running a 4" dynomax muffler, when i hold it up i can look right through. If you want it to sound good make sure you run the pipe or pipes all the way to back to make it sound more deep.
Member # 127099
Other than exhaust is there any other recommendations I have no ideas about diesels I’ve always messed with gas motors and just trying to tinker with this diesel and hoping to learn a few things and get some more power and gas mileage and thanks everyone for your help everyone
Fawkin Fordhead
Now that I think of it, Dynomax I believe it is does build a system for the idi trucks that ends up in a 4" tailpipe.
But, if you're after power and better economy, the turbo is the way to go.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
#7 (permalink) | |
Member # 141697
But yes the trubo is going to be the best mod you can make. |
Member # 127099
Yes I know the turbo would be the best for power and economy but I can’t afford a turbo yet so I’m just trying to get some nice mods on low budget so I’m thinking exhaust and maybe injectors but with injectors would I need a new injection pump and if not what size injectors would anyone recommend
GREEN BASTARD!!!
Member # 123458
Just go to a tractor parts store and tell them you need a muffler for youre old tractor. They should have some 6''dia and 24'' long with 3'' in and out for about $30 or so.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have. |
Member # 134786
I ran 3 inch duals from the manifolds straight out the back with out mufflers loud as hell but it sounded good, if you pull a trailer run the exhaust out the sides otherwise the front of whatever you are pulling will be black and it is hard to scrub it off. Also put a better air intake on it that helps alot too I had a 6 inch tall 14 inch wide K&N on mine with the K&N filter top on it improved my mileage more than I thought it would have. With the C-6 3 spd auto, 4.10 gears, and 33s I was getting 15 to 16 on the highway and better if I kept it around 60 mph.
