This is driving me crazy, help!
I have a 1996 Ford Bronco with pushbutton 4x4.
As I said I have a clunk coming from the right axle when I turn the steering wheel. I had mechanics test drive it, the clunk/pop doesn't occur when they drive it. When I rotate the driveshaft the left axleshaft does not turn. When both hubs are locked, driveshaft is locked. When left hub is unlocked, right is locked, driveshaft turns, left axleshaft turns. If it is the 4x4 engaging Id just buy a manual t-case |
Member # 8941
It sounds to me like the c-clip is bent, and is allowing undue movement in the axleshaft. Its then smacking agenst the knuckle and or hub.
I have never seen such a ruthless bunch of people til i came on pirate... - hawkins1 |
#3 (permalink) | |
Member # 4073
Re: This is driving me crazy, help!
Dustin S. I had a brain-eating disease that died of starvation. |
Member # 8158
Hey MWellner,
Depending on what kind of clunking noise it is, this could be it too: Try grabbing the axle shaft itself. It will move freely in and out of the pumpkin about 1/8 - 1/4". If you push it in hard enough, you will hear it "clunk". This is normal, and nothing to worry about. I went through the same thing (hearing the clunking noise), and just crawled under the truck one day and found this situation. I asked a few others if theirs was the same, and it was. Just a thought. Dean
"Grape Ape" '97 Ford Ranger S/C 4x4, 3/4 ton! - slightly modified! Lifted, Locked, Geared, and Coiled www.grapeapedesign.com |
Member # 7340
Hey see if you can bring it over this weekend. Ill be here Saturday morning, and sunday before 12...........
[COLOR=BLACK] You picked a fine time to leave me loose wheel [/COLOR] |
