Stupid H block for D60 calipers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2010, 10:24 PM   #1 (permalink)
Member # 81189
Hey guys,
I'm putting my 1986 front Dana 60 together and it's been apart
for like a year, I'm just now ready to put the calipers
on but forget how they go on? I don't remember how the pads go
in either? I'd like to see pics or a link to pics...
I bought new dual piston calipers, and everything else...
They came with a new zig-zag wire spring thing and I'm reusing
the old H blocks.
I'm not converting to another caliper, I'm
using what I have.... so buying different brakes ain't happening.
My question is... How do the calipers go on?
Where does the H Block pound into? Where does
the spring thing go?
Sorry, I know this is dumb... I just don't remember how
it goes together.
Can somebody post photos please?
Brakes are kinda important, I want them to work.
'88 Jeep MJ 1-ton buggy
barillms is offline   Reply With Quote
Old 01-29-2010, 06:42 AM   #2 (permalink)
Member # 101946
I would liek to see also. I have been having issues with my ford caliper poping out. That stupid H piece will not hold them in.
I r dumb and can't figure it out
h8to wrk is offline   Reply With Quote
Old 01-29-2010, 08:05 AM   #3 (permalink)
Ibuildembig's Avatar
Member # 26504
Send a message via Yahoo to Ibuildembig
I have seen 86 fronts go either way on calipers....I assume you are using the bolt on style caliper? If you only have the "H" you are missing the spring that goes on top of the "h" before it slides in the caliper bracket. Once in there, there is a bolt that holds the "H" in place. I don't remember there being a zig-zag wire used with that style caliper. Thats used when you have the one piece caliper and is used to keep the pads in place. I will look at my 79 60's when I get home and tell you for sure.
If you have a mullet and play video games, your not tellin me shit
68 F350 CC project
72 F350 CC for parts
79 F150 with tons on coils
88 F350 truggy
90 F350 beater truck
96 F250 CC DD
Ibuildembig is offline   Reply With Quote
Old 01-29-2010, 08:15 AM   #4 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
help?
Old 01-29-2010, 10:12 AM   #5 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
If you have the Bendix style retainer with the h-block and bolt retainer for it, the top of the caliper sildes into the V in the top of the bracket, and the h-block is driven into the opening between the bottom of the caliper and the bottom of the bracket.
If you don't have the bolthole on the bottom and have a V in the bottom of the bracket too, you need to use the goofy Ford retainers with the rubber center in them which drive in top and bottom. The H-block was used until 10/85, the Ford style is later.
This is a chevy, at a weird angle, and it's ground for 15's, but it's the best pic I can find of the H-block setup installed.
http://www.coloradok5.com/d60calipergrind/pic7.jpg
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is online now   Reply With Quote
Old 01-31-2010, 01:54 AM   #6 (permalink)
Member # 81189
Red face
There is NO bolt. When I took the caliper off,
all I did was pound out the H Block... And the caliper came off.
No bolt at all. I just stripped down my buddys 79 Dana 60, and it was
the exact same way.
There's No Bolt at all. Just a block.
I have Calipers, the old H Block & a big zig zag wire spring
that came with the new calipers.
Please post up info about the
H Block mounting of the Ford Dual Piston caliper.
This is a front Dana 60
Old 01-31-2010, 02:00 AM   #7 (permalink)
Member # 81189
Originally Posted by trkklr77 View Post
help?
Sorry dude, this is hilarious.
Nothing in this drawing looks even remotely close
to what my Dana 60 caliper bracket or caliper look like.
Old 01-31-2010, 12:03 PM   #8 (permalink)
mj
Member # 1919
the zig zag spring holds the pads on the caliper,
post pics of this 1979 with no H block retaining bolt, a small slightly bent spring
mj is offline   Reply With Quote
Old 01-31-2010, 12:13 PM   #9 (permalink)
Member # 81189
I'm not posting pics.., im the one that needs
the help here.
I need to see pics on How these
calipers go on!
Old 01-31-2010, 10:15 PM   #10 (permalink)
mj
Member # 1919
i googled it for you
http://www.dieseltruckresource.com/d...-t143024.html?
Old 01-31-2010, 10:19 PM   #11 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
the help here.
calipers go on!
you should post pics of the parts you have, there is 2 different setup and you dont know how to use either.
Old 01-31-2010, 10:45 PM   #12 (permalink)
Member # 103610
Send a message via AIM to jeep937
Originally Posted by mj View Post
That ain't it. We've got the two piston calipers. I'm about to put my 60 together after a long time too. I'll probably need help getting the whole thing put back. How do you install an ARB and 5.13's?
jeep937 is offline   Reply With Quote
Old 01-31-2010, 11:58 PM   #13 (permalink)
Member # 132654
seems like you're looking at some parts like these?
(not the exact parts but similar, disregard that little spring clip on top)
If so the block is oriented with the half-circular cutouts facing down. The spring steel goes on top of the block with the two 90 degree bent ends hanging over either end.
Put the top of the caliper in place on the stand, and rotate the bottom in to place. Its tricky to line it up right, but if you eyeball the area where the block goes as you're rotating it into place you can see where its supposed to be.
'72 ford f-250
[url]http://pirate4x4.com/forum/showthread.php?t=789549[/url]
Antiqueford is offline   Reply With Quote
Old 02-01-2010, 07:15 AM   #14 (permalink)
Member # 26504
A 79 one most certainly does have a retaining bolt to hold the block and spring in place. And for the record, ALL Ford Dana 60 fronts were dual piston caliper. The main thing you need to provide us so that we can help you is a picture or part number of your caliper. Either the caliper is a one piece design or a two piece (bendix) design. Basically, does the caliper have 2 7/8's headed bolts that hold it on the bracket..one at the top, one at the bottom, and you are able to take the caliper off without taking the wheel off?
68 F350 CC project
88 F350 truggy
96 F250 CC DD
Old 02-01-2010, 07:29 AM   #15 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
The H-blocks install and remove exactly the same way on the Ford dual piston calipers as they do on Dodge/GM stuff, and on medium duty stuff, it's all a Bendix style system. There should be a retaining bolt, no matter what, or the h-block will walk out. It's probably sheared off in the caliper stand.
Old 02-01-2010, 08:19 AM   #16 (permalink)
bremen242's Avatar
Member # 28687
Yeah, have fun drilling that out.. had drill and retap mine..
bremen242 is offline   Reply With Quote
Old 02-01-2010, 09:04 AM   #17 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Those H blocks have 2 holes for a reason I think
After the EZ out broke in mine, I just tapped the other hole.
Mark
welndmn is offline   Reply With Quote
Old 02-01-2010, 07:27 PM   #18 (permalink)
bremen242's Avatar
Member # 28687
Yeah, I should have...
Old 02-02-2010, 08:05 PM   #19 (permalink)
Member # 77718
IF this is a 86 front it should NOT use the H block. 78-9's used those. The later ones used a diamond shaped punch pin with small bumps on the ends to retain them. Also there are 2 per side. NAPA has loaded calapers with new punch pins if you have the correct ones. They also have rubber inside them.
'89 B2 with slight modifications
[QUOTE=AZFord4x4;8084876] I really shouldn't download so much porn while I'm trying to ban people.[/QUOTE]
IROK Cherokee is offline   Reply With Quote
Old 02-02-2010, 08:17 PM   #20 (permalink)
bremen242's Avatar
Member # 28687
Don't know about '86. Both my '85 F250 & F150 used the H Block.
Old 02-03-2010, 08:02 PM   #21 (permalink)
Member # 73465
Sorry it took so long, I was on tour...
one of the pics shows the spring for the caliper/pads.
Let me know if you need more pics or other views.
Good Luck!
Got Ford?
3 Early Broncos, 2 Classic Mustangs, 68 F100, 71F250 4x4, 2 Lincoln Mark VIII - BF Penn
[QUOTE=nahmus;10554695]This country is trying to childproof the world when they should be worldproofing their children.[/QUOTE]
71PA_Highboy is offline   Reply With Quote
Old 07-26-2010, 11:44 AM   #22 (permalink)
"All Whee Drive!"
MochaMike's Avatar
Member # 6450
BTT.
I understand exactly how this thing goes together.
I've been trying to install the H shaped block & the long C shaped spacer for better part of an hour.
Unless I hold the caliper with one hand, it keeps falling out.
I get the spring in, & can kinda hold onto the H block, but I can't line it up/start pounding it in with my BFH.
Is there a trick to this?
Or did they seriously design this from the factory as a 2 man job?
EDIT: I just had a thought/question someone might be able to answer.
Could I have installed the caliper brackets on the wrong sides/upside-down?
Does the H piece go on the top or bottom?
Mine is currently on the bottom (bolt is there also).
50yo IH Scout Parts
WeBilt 4x4
Originally Posted by RustoleumWhite View Post
Binder Planet is the Church, or Community Center, Pirate is the Bar. You'll get good tech at both places, but here you have to take the shit with the good stuff.
MochaMike is online now   Reply With Quote
Old 07-26-2010, 11:51 AM   #23 (permalink)
4x4e350's Avatar
Member # 130521
I just put mine together Saturday. Are you sure you have the retention spring between the H-block and Caliper? It should just slide in while you hold the Caliper against the rotor.
1989 E350 Ambulance 4x4_Buggy TTB, 10.25, 1356 Doubler, budget built_1971 M818 four door
4x4e350 is offline   Reply With Quote
Old 07-26-2010, 11:52 AM   #24 (permalink)
4x4e350's Avatar
Member # 130521
Originally Posted by MochaMike View Post
BTT.
Bottom.
Old 07-26-2010, 11:55 AM   #25 (permalink)
"All Whee Drive!"
MochaMike's Avatar
Member # 6450
Edit: I can get the H block in without the spacer, it's rather snug (needed to be hammered in). But not super tight...
Do I need the spacer?
50yo IH Scout Parts
WeBilt 4x4
