full hydro steering ?
i am about to do a d60 swap in my truck here real soon and i am definitely not keeping the stock ford steering or any other stock system. i wanted to know if anyone knows of any company that makes full hydro steering kits for a ford. i know that psc does one for chevys, but the hp pump would not bolt on to a ford bracket. could i just use that kit and just make my own bracket for the pump and it still work? also would my ford steering shaft work for a psc steering box? anyone who has done a full hydro on a ford give me some advice
Member # 128152
should have googled... you could have saved yourself from getting smart ass remarks from people with nothing else to do ,so with that said,look here http://www.pscmotorsports.com/
'74 ford,tube frame,rear eng,blown BBF,C-6,Profab, GM 2.5 ton front ,F106 rear, F/R lockers |
Cheapest easiest way:
Double ended cylinder from surplus center NAPA heavy duty saginaw replacement for 79 f150 high steer arms and heims from anyone DOM tubing Orbital valve from 4600 JD combine Manifold from 4600 JD combine Steering wheel center from 4600 JD combine Have someone make your lines and you are done I have the same thing on my crawler and did it all for 325.00 ohhh, run nothing but royal purple max-ez p/s fluid
If you have a mullet and play video games, your not tellin me shit ![]() 68 F350 CC project 72 F350 CC for parts 79 F150 with tons on coils 88 F350 truggy 90 F350 beater truck 96 F250 CC DD |
