#326 (permalink) |
Member # 70242
i hate to hijack your thread about your awesome truck but how do you like the 485 quad trac. Ive got 2 9380's and there getting alot of hours built up so im lookin to start replacing them. ive heard really good things about the newer quads but have seen some control issues on the inside. I could go on but i dont wanna clutter up your thread. thanks
96 ranger with hp44,31spl9, coils....89 jeep wrangler 5.0, aod, black box with triple stick 205, 79 hp60,70u,5.13s, 44" fc2's, . fucncrawlin
#327 (permalink) |
Member # 56693
sorry i cant help ya with that dude, its not my tractor. its a neighbors. i've always been a IH fan, so i had to take a pic one day. they seem popular out here in ND though
"America is at that awkward stage. It's too late to work within the
system, but too early to shoot the bastards." ![]() '79 F-350 Crewcab, Cummins, 6spd. 37s NPF chassis, 6.0, 4L80E, 404s, 42s, ![]() NUKEPROOF FAB. Last edited by montanatrout; 02-26-2011 at 01:23 PM. |
#328 (permalink) |
Member # 56693
rebuilding NV5600.......
just found this, pretty good in my opinion for someone who hasnt ever done one. i'll be doing mine this summer. Thanks to whoever made this....
http://dodgeforum.com/forum/dodge-cu...rk-nv5600.html
system, but too early to shoot the bastards." ![]() '79 F-350 Crewcab, Cummins, 6spd. 37s NPF chassis, 6.0, 4L80E, 404s, 42s, ![]() NUKEPROOF FAB. |
#329 (permalink) |
Member # 56693
Got an update, she's been running and driving great. Ive put about 20k on her now since the cab swap. I finally got rid of the aluminum dually spacers and got a pair of real dually hubs. they ended up being 5" wider per side than SRW hubs, FYI.
I also just wipped out a spare tire carrier. I had no way to carry a spare when I had my slide-in camper on. now i do. Eventually I will put mounts for two gas cans that will go to the right (pass. side) of the tire. and a Hi-lift mount. I built it out of 2".120, just like all the other tube on the truck. I used Ruffstuff .375 thick suspension tabs so I can back into trees and not bend them. and the bushings are poly. The buggy im building is using Unimog 404 axles, and this is a spare custom 8 lug hub for it. It doubles as my tire mount The reason the carrier is not flat is cause the bed is about 7'6" long, and my camper is a full 8'
system, but too early to shoot the bastards." ![]() '79 F-350 Crewcab, Cummins, 6spd. 37s NPF chassis, 6.0, 4L80E, 404s, 42s, ![]() NUKEPROOF FAB. Last edited by montanatrout; 11-01-2011 at 08:11 PM. |
#331 (permalink) |
Member # 29868
Looks real slick there Chris. Is the pass side the same style mounts? How about a shot with it swung open? Must get to work on my own junk.....
1996 Tacoma V6 5spd, duals, Dana 60, 14 bolt, 5:38's, 42" Iroks, exo-cage 1997 Dodge Cummins 5spd 4x4, 79 Dana 60 under leafs, Dana 80, 4:10s, 37's /forum/tow-rigs-trailers/850288-1997-dodge-cummins-towho-expo.html |
#332 (permalink) | |
Member # 56693
i'll get some more shots if i can get home before it gets dark
system, but too early to shoot the bastards." ![]() '79 F-350 Crewcab, Cummins, 6spd. 37s NPF chassis, 6.0, 4L80E, 404s, 42s, ![]() NUKEPROOF FAB. Last edited by montanatrout; 11-02-2011 at 04:29 PM. |
#333 (permalink) |
Member # 56693
I am finally going to be doing the gears in the fodge. Right now i have 3.54s, and with the 37's it isnt the ideal setup. A friend of mind runs 37s with 4.10s in his 12 valve/nv4500 and likes it. If im gunna do new gears, should i go with the 4.10s or go for the 4.56s? I can only find a 4.63 for the 80, so the front and rear will have a .07 ratio. That wont cause a problem on snow and dirt.
Whatcha think, 4.10s or 4.63s?????????????? with 4.10s i'll be at 1903rpm @ 70mph with 4.63s i'll be at 2149rpm @ 70mph
system, but too early to shoot the bastards." ![]() '79 F-350 Crewcab, Cummins, 6spd. 37s NPF chassis, 6.0, 4L80E, 404s, 42s, ![]() NUKEPROOF FAB. Last edited by montanatrout; 01-29-2012 at 01:02 PM. |
#335 (permalink) |
TANK
Member # 131367
i would stick with 3.54s unless you tow alot. occasional towing you can always drop down to 5th. if you do tow a lot 4.10s are a good in between. easier to start in 1st, not wound up to fast in 6th. 4.56's are pretty deep for a cummins. as you know there torque comes in down low, around 1700-2000 and tapers off at 2600 or so.
3.54 at 75 mph would be 1760 rpms 4.10 at 75 mph would be 2038 rpms. 4.56's at 75 mph would be 2200 rpms. edit, just reread your post, do 4.10's
Originally Posted by GONRACIN it's far better to have more truck then you need, than to need more truck then you have.... Last edited by bf; 01-29-2012 at 01:11 PM. |
#336 (permalink) | |
i win diesel!!1!
Member # 158768
personally i'd go 4.10s. it's not like you have a whole lot of powerband to play with with a diesel. but a quick question: how much time do you spend cruising at highway speeds? if it ain't much i'd consider the lower gears.
web wheeler 4 life. Quote:
#337 (permalink) |
Member # 56693
the 3.54s are not gunna stay. the only time i can get into 6 is cruising at 70-75 empty and then im at 1600ish. way to low IMO. a stock 1 ton cummins cruising rpm is about 1900-2000.
I would rather have a little more towwing power i think. The truck is my DD but i dont do an interstate commute with it every day, i drive around town, and when on the hiway the limit is 65-70 in mosyt places. other than that it's hooked to something. It seems from what ive read the 24 valves like a little high rpm than the 12v's so the should put me at 4.63s right?????????????
#338 (permalink) |
4.63's and dont look back. its not too much from the 4.10 but that lil extra grunt will be great for pulling
'94 F350 CC .030 460 Auto 4x4 "Tow Rig" '78 F350 Sittin Pretty On 39.5 Boggers R.I.P. '94 Ranger 3/4 ton 5.8L 38.5 Boggers Taylor |
#339 (permalink) |
Member # 56693
ya, and the 4.63's will help someday when i get a newwer tow rig, the fodge will get more dirtier with 40's
#340 (permalink) |
Member # 29868
As you well know I have the 4.10's, NV 4500 with 37's and am happy. I looked around and there is also a 4.30 gear option. 4.63's sound a little deep to me, I think you'd really be revving on the highway. We have an F550 fire truck 7.3 powerstroke with 6spd and 4.88's and I am usually in 6th before 50mph. I'd consider the 4.30's pretty hard, might just be the perfect split.
1996 Tacoma V6 5spd, duals, Dana 60, 14 bolt, 5:38's, 42" Iroks, exo-cage 1997 Dodge Cummins 5spd 4x4, 79 Dana 60 under leafs, Dana 80, 4:10s, 37's http://www.pirate4x4.com/forum/showthread.php?t=850288 |
#341 (permalink) |
RokRash
Member # 105287
2149@ 70 doesn't sound that far of from my stock 3500. Almost exact. I'd do the 4.63'. Then the 40's
Guns in the hands of honest citizens save lives and property, and gun-control laws adversely affect only the law-abiding citizens. support the NRA http://membership.nrahq.org/ Last edited by rocky mnt. crawler; 01-30-2012 at 07:10 AM. |
#342 (permalink) |
Member # 56693
ya thats what i was thinkn. the fodge is great, but someday when i can justify a new rig, the fodge will be the new big wheeler. I think she'll do great on a set of 40s. Then it wont have to be the only tow rig in the barn
#343 (permalink) |
Member # 197826
kick ass build someday my 77 supercab will get the 4x4 cummins swap
87 RANGER XCAB 4LINKED ON 38'S 302 C6 205 77 FORD SUPERCAB STEPSIDE HIGHBOY DIESEL COLLECTING PARTS |
#344 (permalink) |
Member # 56693
built a front axle truss today. 3/4" and 1/2" round bar. now there wont be any worry about catchin a little air every now and then. the 1/2" plate on the C's beef them up too.
system, but too early to shoot the bastards." ![]() '79 F-350 Crewcab, Cummins, 6spd. 37s NPF chassis, 6.0, 4L80E, 404s, 42s, ![]() NUKEPROOF FAB. Last edited by montanatrout; 04-29-2012 at 06:28 PM. |
#346 (permalink) | |
is gettin it
Member # 169361
I couldnt believe my eyes when i saw someone on here from rr oregon too. lol cool truck btw! Last edited by 223; 05-18-2012 at 06:11 PM. |
#347 (permalink) |
Member # 29868
Bump because I am building a flatbed, basically copying this one and am sick of searching every time I need to look at the Fodge.
#348 (permalink) |
Member # 56693
maybe you should just subscribe to the thread there buddy
![]() we have a couple slow days at work so............being that summer is HOT in nodak (95 for sat.) we nee A/C!!!! the plan is to use the HVAC unit out of a 97 dodge ram. its all under dash, uses vacuum controls, is relatively compact. the ford unit the AC end of it is in the engine compartment and is very much in the way of the turbo. i didnt want to rework all that stuff, so into the dash we go........... old and new.... what a mess!
#350 (permalink) |
Member # 56693
its done and work fawkn awesome! even with it only blowing on the floor and defroster ducts. i have to build a dash vent. my pickup never had them from the factory and the dodge ducting was not fitting the way i wanted. so i'm gunna integrate the dash vent into a center console between the dash and shifter. its gunna be cool. pun intended.
as far as vac. controls im looking at a switch cluster from a 92-97 ford......we will see
