Specs on SB C6 vs E4OD - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-01-2010, 11:49 AM   #1 (permalink)
wheelin66bronco's Avatar
Member # 44308
Anyone have a link or facts on the two? I've searched and can't drum up much on side by side info.
I'm going to be building a +/- 450hp 408W in the new car I'm building. I'm going to be running 89-93 MAF fuel injection. Trying to decide if the E4OD is worth building for the extra low range and OD.
Will the 89-93 MAF computer run the E4OD?
What is the difference in how much HP each trans pulls. I know the C6 is something like 50hp.
I've run a SB C6 behind my 325ish hp 351W for a few years now, no issues and I built it myself so I'm a little hesitant to change but I'd really like the OD for the new car.
The car will be desert raced and beat on pretty hard.
Will a well built 94-95 E4OD with all the updates hold that kind of power and live very long? Lots of cooling etc is obvious.
ΜΟΛΩΝ ΛΑβΕ
98' 12v, qclb, lots of fun parts. No rice
96' Bronco Sport build
You know why black people never get bitten by sharks? They think it's whale shit.
wheelin66bronco is online now   Reply With Quote Quick reply to this message
Old 03-01-2010, 12:06 PM   #2 (permalink)
rhinomxer's Avatar
Member # 72964
The E4OD is more expensive and more rare. The C6 is easy to find. The big advantage to the E4OD is obviosly the OD.
I'm not sure what power either are rated up to. If it were me, I'd stick with what I know works.
rhinomxer is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 01:25 PM   #3 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The E4OD is pretty much an updated C6 with overdrive on the back, when built, they are a good strong transmission, and you can build one far stronger than you can a C6 thanks to the diesel guys.
No, a MAF 'Stang computer isn't going to run one, you need to either play with a truck MAF setup(94-96) or run a standalone controller. The second one being preferrable as the truck computers aren't really well cracked.
If you don't need the OD, the planetaries from an E4OD work just fine in a C6, and will give you the same wide ratio setup.
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 03-01-2010, 02:02 PM   #4 (permalink)
Member # 38200
The E4OD use torrington thrust bearings instead of washers, so they have a little less drag than the C6. The bearings can be retrofitted to a C6 as well.
Quick & Dirty is offline   Reply With Quote Quick reply to this message
Old 03-03-2010, 07:05 PM   #5 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
you can put the planets in the C6 as well.
What the heck do you need overdrive for?
Just run the C6, it will be way cheaper to build.
Mark
Old 03-03-2010, 08:59 PM   #6 (permalink)
Danger Ranger's Avatar
Member # 1234
the bling shit for the c6 isn't exactly *cheap*
I have the e4od 1st/2nd in my c6 with the torrington bearings, red eagle clutches, kolene steels, wide kevlar band, r-code servo, badass torque convertor, deep pan, blah blah blah and I'd love to tell you how it all works... but that's a long story I now also have a full man reverse pattern valve body. There's over $2k just in parts in my c6 now...
The 4r100 (big brother to the e40d) in my PSD was a $4k+ trans with all the badass parts.
I think I still hate autos!
If not today nor yet tomorrow then some other day
Danger Ranger is offline   Reply With Quote Quick reply to this message
