I'm building a 94 bronco with a D60 and 10.25. I'm pulling the axles off my old 85 bronco. I need to know if the crossmembers are the same. I trimmed the 85 crossmember for clearance, so to put the TTB on it I need to swap the crossmember from the 94 over to the 85.
Are you talking about the front engine crossmember? If so they maybe a little different but it would be a lot easier to modifiy the 94' to make it work with your SAS swap. I have never tried, but have modified almost anything you can think of with that body style and frame. But I bet that crossmember won't come out with out a fight.
Ok thanks. I havnt' seen any welds on either of the crossmembers... They're probably under the grease and oil.....
