95 Ranger Build - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2011, 04:40 PM   #101 (permalink)
Member # 127442
I think it looks alright!
not gonna be a dash till i get the cage done once its done i will build a dash for now ive just got a little mount for m guages oh shit bar will also get changed when i do the cage.
[CENTER]95 Ranger 5.0L Built 4R70W 203-205 D-60 14B 3 link front 14'' kings 250lb-400lb 63"chevys detroit rear powertrac front 37' creepy crawlers.
Build thread here[URL="http://pirate4x4.com/forum/showthread.php?t=878737"]http://pirate4x4.com/forum/showthread.php?t=878737[/URL]
[B]Support the BRC![/B][/CENTER]
Ford rules is offline   Reply With Quote
Old 08-04-2011, 01:54 PM   #102 (permalink)
Member # 127442
Drove it up to the house!
Old 08-04-2011, 02:30 PM   #103 (permalink)
Member # 127442
Old 08-05-2011, 04:20 PM   #104 (permalink)
Member # 127442
So the truck is missing under load and trying to accelerate.
I replace all plugs with NGK v-powers replaced a 02 sensor and added some fuel injector cleaner.
I replaced the coil packs just before the winter i geuss they could be bad anyone know how to check them?
Also probably gonna replace the fuel filter.
Old 08-06-2011, 06:28 PM   #105 (permalink)
Member # 127442
Changed the alternator today its charging now so thats good but its still missing
Old 08-06-2011, 06:43 PM   #106 (permalink)
Member # 127442
Old 08-10-2011, 10:59 AM   #107 (permalink)
Member # 127442
Trucks pretty much done asides from painting the fenders and installing them.
Poser shots.
Shifters done
My trucks and my brothers cummins
Setting up twins hx35 and a ht3b
Old 08-10-2011, 11:44 AM   #108 (permalink)
Member # 65341
Did you get the miss resolved?
2012 JKU, RK 3.5" Flex, 35s, armored up and ready to wheel.
2004 TJ, 2" BB, ugly ass green.
Freshmeat is offline   Reply With Quote
Old 08-10-2011, 07:40 PM   #109 (permalink)
Member # 127442
Yea.... felt like an idiot when i found the problem. It ended up that it was out of gas, i didnt think to check since a few months ago i filled the cell up and hadent run since then so i geusss someone syphoned it out or it evaporated ohh well 5 gallons later and it runs great atleast i know all my sensors are in working order since i checked em all looking for the problem!
Old 08-11-2011, 10:19 AM   #110 (permalink)
Hillbilly Redneck
302B4's Avatar
Member # 173422
Glad you got the missing problem resolved. I don't think a full cell of fuel would evaporate. Possibly a leak though....
Something to keep an eye out for. Put some carboard under the truck by the cell and you could see if it gets wet.
Or it could have been stolen like you suspected.
302B4 is offline   Reply With Quote
Old 08-11-2011, 06:38 PM   #111 (permalink)
Member # 127442
I doubt it was stolen its been in the barn the whole time and im pretty sure it dosent leak but idk hasent lost anymore fuel so im happy.
Truck does have a death wobble problem anyone have sugestions as to what would cause it.
caster is at 4* and the truck is set at 1/8'' tow in and the driver side is .25'' less wheel base than the passenger side. drag link to trac bar angle is pretty close and about the same length.
Both king pins are rebuilt with new springs, the springs were tightened and loosened 5 times or so could this wear them out enough to cause death wobble.
Old 08-11-2011, 07:24 PM   #112 (permalink)
Member # 127442
Did some more searching and im gonna try shimming the KP bushings im thinking this is causing my problem and may also add a steering stabilizer. ill report back with my findings.
Old 08-12-2011, 07:22 AM   #113 (permalink)
93ranger4x4's Avatar
Member # 121782
this picture has been a big help.
93ranger4x4 is offline   Reply With Quote
Old 08-12-2011, 01:32 PM   #114 (permalink)
Member # 127442
Not a problem i figured out to do that from a thread on here anyways.
Old 08-21-2011, 06:08 PM   #115 (permalink)
Member # 127442
Trucks basically done for now heres some pics
Old 08-24-2011, 06:27 PM   #116 (permalink)
Member # 127442
Got my resevoirs mounted up and tach is wired up.
Went to a boat launch by my house and snagged some pics.
Old 08-25-2011, 10:25 AM   #117 (permalink)
Disturbed Sledneck's Avatar
Member # 194985
Sweet build.
You might hear some bitching about the truck being in the lake. Just sayin.
Disturbed Sledneck is offline   Reply With Quote
Old 08-25-2011, 12:10 PM   #118 (permalink)
Member # 127442
Thanks!
Ahh its no different then a boat and it dosent leak any fluids!
Old 08-25-2011, 11:01 PM   #119 (permalink)
rstangboi's Avatar
Member # 125673
TITS! lovin it man. but moar pics are a must.
your makin me think long and hard about skinning my bed.
2001 Ranger- SAS'ed, 35's, d44/d60, dual cased
2004 F-250
rstangboi is offline   Reply With Quote
Old 08-26-2011, 04:11 AM   #120 (permalink)
Member # 127442
Thanks alot i like the bed skinned but sometimes wish i still had a full bed to use...
Old 08-26-2011, 05:39 AM   #121 (permalink)
bronkho31's Avatar
Member # 74474
Send a message via AIM to bronkho31
Good looking ranger. I noticed you had some -weld your own- headers in a previous pic, are those what you went with and how hard were they to do. Im working with almost the same thing you have but mines a 351w so a little tighter space.
Keep up the good work
IL Air Natn'l Guard
1Ton Ranger Project - F250 7.3 Piped/Intake/Chip/Leveled
bronkho31 is offline   Reply With Quote
Old 08-26-2011, 05:22 PM   #122 (permalink)
Member # 127442
I was going to build a set but i ended up getting away with using the headman swap headers still had to make new exhaust but it works.
Ive made headers before though for either turbo applications and N/A applications, there really not as hard to make as people think little patience and a little for thought goes along way.
Old 09-02-2011, 05:42 PM   #123 (permalink)
Member # 127442
Well?
Old 09-02-2011, 06:11 PM   #124 (permalink)
fishforlife2007's Avatar
Member # 175179
sex.
fishforlife2007 is offline   Reply With Quote
Old 09-02-2011, 06:16 PM   #125 (permalink)
Forever being built
wahlstrom1's Avatar
Member # 94308
Looks good man! I'm way to lazy to go back and fire the tire size your running.... 39/17?
Originally Posted by Rocky View Post
Never thought I would ever get excited about a backsplash or faucet, but I never had a sink with a front diff before either....
wahlstrom1 is offline   Reply With Quote
