Flat towing with a 1354 manual tcase - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-23-2010, 12:49 PM   #1 (permalink)
inh
Member # 137757
So I want to tow my 2000 Explorer 4x4 from CA to MO via tow bar behind a Uhaul. from what I've read so far. Transmission (auto) in neutral, transfercase (1354 manual) in neutral. I shouldn't need to pull the driveshaft as a lot of Jeep owners do, because the oil pump in the tcase is driven by the rear driveshaft output, as per http://www.therangerstation.com/tech...nual_TCase.pdf:
According to uhaul, however, if a 91 ranger 4x4 were to be towed on a tow dolly, the rear drive shaft would need to be removed.
Any insight on this?
inh is offline   Reply With Quote
Old 04-23-2010, 03:02 PM   #2 (permalink)
Member # 10063
You are correct, U-haul is wrong.
However I'm a bit confused as to what you're towing... A '91 Ranger? or a '00 Explorer?
If the Explorer, I don't believe that year ever came with a manual t-case. So unless you've swapped one in, you'll need to pull the driveshaft on that (might need to pull BOTH driveshafts, as the front will still be turning also).
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 04-23-2010, 03:26 PM   #3 (permalink)
Member # 37770
Send a message via AIM to 93chico4by
Pull the driveshafts.... it is free insurance against possible extreme carnage.
Bronco Foot - '84 BroncoII 5.0/C4/Atlas D35 TTB/8.8
93chico4by is offline   Reply With Quote
Old 04-23-2010, 10:11 PM   #4 (permalink)
inh
Member # 137757
Sorry, yes, I swapped the 1354 in to my 2000 explorer. Thank you for the help guys, if anyone else has any input I'd love to hear it =]
Old 04-23-2010, 10:12 PM   #5 (permalink)
mjlogan88's Avatar
Member # 23553
X2
i had that extreme carnage when my front driveshaft u joint exploded when flat towing with my tcase in neutral. front driveshaft then blew apart taking out fuel lines and all sorts of other crap. not fun
[QUOTE=davey2451;8082797] i just looked at mjlogan88's ranger and it sucks [/QUOTE]
If all else fails, immortality can always be assured by spectacular error
mjlogan88 is offline   Reply With Quote
