Tried searching with no luck. Think my search fu is weak.
I've got a 97 7.3 F-superduty 2wd that I need to replace the trans in. Its a ZF 5 speed with the parking brake on the extension housing. The brake housing is trashed as was common on these and I can't find a good replacement brake housing for under $1k.:shaking:
I found a ZF from a 94 7.3 F-350 2wd thats complete with the brake assembly for a decent price however I am finding conflicting info if they are interchangable as either the entire trans or just the brake parts.
I've read that the 97 and up ZF's are different in some ways but nothing that says a definate yes or no if it will work.
