The gasket in between the tranny case and the 4wd adaptor began leaking. With the tranny still in the truck I got it seperated about 1/4" the gasket came out just fine, the passenger side was messed up. If I just use some gasket maker ( Loctite 518 ) clean the surfaces put this on and pull it back together, will this create any clearance issues in the tranny? I know the gasket has a certain thickness.
Without the gasket in place would it be too tight?
