Newbie
Member # 21579
Shallowest 302 0il Pan
I have a 91 F-150 302 motor in my trail rig. The oil pan hangs down lower than I like & keeps getting smacked to the point of failure. Does anyone know of a shorter pan. I was thinking possibly mustang double hump or explorer. I am not opposed to aftermarket but do not want dry sump. Only needs to be about 2" shallower. ( then I could build a flat skid) Any one that has messed with this, your advice would be greatly appreciated. Its no fun putting a hole in your pan at a 3:00 Am on a night ride!!
#2 (permalink) | |
Fir Na Dli
Member # 79002
I think a fox body mustang pan is gonna be about the best you could do.
Budget trail whore: 1985 BroncoII Eddie Bauer. V8/Automagic/Locked/MTRs. Quote:
Member # 77346
I'd go with one of those "shoebox" looking pans from Summit. But, if you have a welder, fab one up.
'94 Bronco, 5.8L/E4OD, custom bumper and winch "I left paint behind at the Coppermines" |
#5 (permalink) | |
Newbie
Member # 21579
Thanks
Thanks!!! |
Member # 110936
oil pan
Don't go with an Exploder pan...the one I have sitting in my garage is CAST ALUMINUM. Smack it once and you are done.
89YJ/302/C6/205/HP44/14B/37"CLAWS on 17s and IROKS on ReCentered H1s...up next 5.0L/AOD/205 |
Newbie
Member # 21579
pan clearance specs 302
Got a 91 mustang fox body factory oil pan with the pickup tube. The Truck pan was about 9.5 inches from the flange and the Mustang was around 7 3/4 inch with the drain plug taking it to about 8 inches. The pan gasket was the same for the mustang pan & the truck pan. I had to swap the pickup due to depth and cut about 3/4 inch off the factory dipstick ( bottom of new pan clearance) . I then put 5.5 quarts of oil in and ziz wheeled a mark on the dipstick in the new location. Not very high tech but was done in under 1.5 hours. Now I will have room to run a flush belly pan to protect the oil pan!!!!!!
