Anyone running H1 rims on their D44? Or...anyone who has rims with deep backspacing like the H1's? I believe they are 16.5 x 9" wide with 7" BS.
I'm about to use an F250 high pinion D44 under my Sonoma and don't mind the tires sticking out a little bit, but I want to use rims with no less than 5" backspacing to keep the width at a minimum. 6-7" BS would be ideal on an 8.5-9" wide wheel. I drive in states with pretty strict fender laws.
Anyone running similar specs? Please post a front shot and let me know if the rims hit anything (tie rod, high steer arm, caliper, ect ect).
Edit: BTW, I don't want to use bolt on spacers to prevent anything from rubbing because that would negate the idea of keeping things narrow.
Thanks in advance.
Thanks in advance.
